Check out www.picobay.com/vb.html. There is some pretty slick serial
port interface software that allows you to capture output from a
STAMP and copy/paste the data into another application. I've used it
and it works great!
Hope that helps.
--Jeff Wallace
-{Add a RTC, 128K or NEW 256K EEPROM and an I2C bus to your STAMP}-
www.High-TechGarage.com/products/timekeeper.php
> Using win2k, is there a way to capture debug output to a file, or
> copy it to the clipboard?
Hi, I got that interface and it does not work for me for some reasons?
Does it require modifications? I am using com 1....? It says that the
port cant be found or is being used...?
Corey C.
--- In basicstamps@y..., bs2web@y... wrote:
> Hi Jay,
> and it works great!
> Hope that helps.
> --Jeff Wallace
What baud rate is it set at? Mine is working with 9600, no parity and
8 bits. Also, make sure you click "Open" so that the software will
open the port. Be careful, this will reset the STAMP (I lost some 2
days worth of data logging memory this way...)
reasons?
the
> Thanks,
> Corey C.
> > Hi Jay,
serial
it
> > and it works great!
> > Hope that helps.
> > --Jeff Wallace
STAMP}-
and it works great!
Hope that helps.
--Jeff Wallace
Corey C.
> Hi Jay,
> and it works great!
> Hope that helps.
> --Jeff Wallace
reasons?
the
> Thanks,
> Corey C.
> > Hi Jay,
serial
it
> > and it works great!
> > Hope that helps.
> > --Jeff Wallace
STAMP}-
