LM339 Question (Beau Schwabe)
Beau, The circuit that I an doing is the National AN-453, you know
the AIC. well do you think I can use the LM324 for the circuit on
page 4? or will I have to add a diode?
TC
--- In basicstamps@y..., "Beau Schwabe" <bschwabe@a...> wrote:
> At 09:24 PM 5/3/01 +0000, you wrote:
> >Hello all,
> >Dose any one know if I can use A LM324 inplace of a LM339 for a
> >project? The sheat that I got says to use a LM339, well I got a
LM324
> >that I had laying around.
> >please help
> >TC
> The short answer to your question is YES because you are using an
> Op-Amp in-place of a Comparator. If you were using a Comparator
> in-place of an Op-Amp, I would be more hesitant to say YES.
> ...your circuit however might require a diode on the output on
> each Comparator...
> Old Output >
|<----> New Output
> ...The diode allows the remainder of the circuit to "think" that
> it has the "open-collector" outputs on the OP-Amp (LM324) that
> would typically be on a Comparator. (See below) ...although it
> is possible that the circuit doesn't care either way, you may not
> even need the diodes.
> Your question is more of an application dependent question...
> The most substantial difference between a Comparator (LM339) and
> an Op-Amp (LM324) is that the Comparator is Open Collector, meaning
> that it is never driven HIGH.
> In most circuits where a Comparator is used, it might be ok to
> substitute an Op-Amp.
> On the other hand, in circuits where an Op-Amp is used, it is
> unlikely that a Comparator could be used as easily. But again, this
> mainly depends on the application.
> See: http://www.national.com/pf/LM/ for a list of datasheets....
> ...under the LM339, take a look at page 15 and compare that
> schematic to the LM741 page 4, and see how much they differ.
> The Op-Amp is driven both HIGH and LOW, while the Comparator
> is only driven LOW.
> Beau Schwabe IC Mask Designer
> National Semiconductor Wired Communications Division
> 500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
TC
> >Hello all,
LM324
> >please help
> >TC
> each Comparator...
> Old Output >
|<----> New Output
> is only driven LOW.
a LM324.... I would use the diodes because of the 3.3K pull-up
resistors in the schematic, and because I don't know what kind
of currents the COP452's and COP444L are expecting. The 3.3K at
least limits this to about 1.5mA of current. The LM339 in this
circuit functions more as a buffer to the remainder of the circuit.
BTW) Any reason you don't want to spend $2 on a LM324?
>TC
> > >Hello all,
>LM324
> > >please help
> > >TC
> > each Comparator...
> > Old Output >
|<----> New Output
> > is only driven LOW.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
around. But, Thanks for your help
TC
> Looking at the schematic, it would probably be ok to substitute
> >TC
> > > >Hello all,
> >LM324
> > > >please help
> > > >TC
an
> > > each Comparator...
> > > Old Output >
|<----> New Output
not
meaning
this
that
differ.
Comparator
> > > is only driven LOW.
30071
