Labels for project enclosure — Parallax Forums
edited 2001-05-04 17:16 in General Discussion
I need to label some switches, LED's, jacks, etc on a black plastic
project enclosure. The surface os slightly textured, so I'm not sure
how well "stick-ons" will stay attached. I had thought about "rub-
ons", but the only ones that I could find were too large and they
were black.....
Any suggetstions?
    edited 2001-05-04 01:14
    Mike,
    We just went through this process, with the added feature that our labels
    had to be "UL approved" meaning withstanding rubbing with isopropyl alcohol.
    After investigating many options, we finally adopted an excellent suggestion
    by Tracy Allen: go with a Brother label maker. They use "TZ Tape" in
    different colors and backgrounds. For a black plastic enclosure panel, we
    now use the gold letters on black background. The tape is multilayer, with
    a protective outer layer, and an excellent adhesive. It passed the UL
    tests, with no problems. The tape works fine in the low-cost hand held
    machines. But for production work, we went with a larger Brother printer
    that has a computer interface (also recommended by Tracy). It allows us to
    use wider tape, print our logos from image files, and store the files for
    later use.
    By calling Brother directly, we purchased a guaranteed, reconditioned
    printer for half the cost of a new one.
    Dennis
    Dennis O'Leary
    WSR, Inc.
    Pasadena, CA
    From: Michael [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BVtAcDlppvYLumRSNZgBptcP2Ke9r3QJoUBuI-aoBnaszxo77dbhdWrvqbD3QlZ4kAzaP_BaVnWRBkueMutJ]mstone@g...[/url
    Sent: Thursday, May 03, 2001 3:55 PM
    Subject: [noparse][[/noparse]basicstamps] Labels for project enclosure
    were black.....
    Any suggetstions?
    edited 2001-05-04 14:13
    I agree. we use one here and the labels even hold up fairly decent outside. If
    you have the computer interface one and a paint program you can make just about
    any label you want.
    "Dennis P. O'Leary" wrote:
    > Mike,
    > Tape"..............
    edited 2001-05-04 14:43
    I have a Brother TZ labelmaker also. Works great, but I wish I would have
    spent the bucks on the more expensive model that has the PC interface and
    prints multiple lines. There are a butt-load of different TZ tape colors and
    stuff available, but most office supply stores only stock the normal ones.
    The black on yellow is my preference for high-viz stuff.
    outside. If
    about
    > any label you want.
    labels
    alcohol.
    suggestion
    > > Tape"..............
    Hi Mike,
    Hey Dennis. I'm pleased you like the Brother tapes too. We use them
    here for our Stache labels (black on yellow
    <http://www.emesystems.com/stachedat.htm >) and also for other
    products. They even hold up well even in sunlight and weather.
    Mike, you mentioned that you have a textured surface. That might be
    a problem. One thing you can do to increase the adhesion is to heat
    up the label on the surface with a hair dryer and rub it down.
    For larger labels I print legends on mylar film and then laminate the
    ink side. Then use a transfer adhesive on the back. You can get
    some pretty thick, aggressive transfer adhesives.
    -- regards,
    Tracy Allen
    mailto:tracy@e...
    >I actually have a Brother label maker at work. I had not thought
    >about using it, but I'll definitely give it a try.
    >Thanks again,
    >Mike
    >--- In basicstamps@y..., "Dennis P. O'Leary" <doleary@h...> wrote:
    > > Mike,
    >labels
    >alcohol.
    >suggestion
    >in
    >panel, we
    >multilayer, with
    >UL
    >held
    >printer
    >allows us to
    >files for
    > > later use.
    >reconditioned
    > > Dennis
    > > Dennis O'Leary
    > > WSR, Inc.
    > > Pasadena, CA
    > > From: Michael [noparse][[/noparse]mailto:mstone@g...]
    > > To: basicstamps@y...
    >sure
    > > were black.....
    > > Any suggetstions?
    > > Thanks,
    > > Mike
