math help
Archiver
can someone please help me make a BS2 to do this math problem:
N*3600/M
N could be up to 700
M could be up to 18000
If you use a calculator you will get "140"
but if you use the stamp you get "1"
Please help
TC
N*3600/M
Please help
TC
N*36/(M/100)
M/100 ranges from 0-180, so no problem there.
N*36 ranges from 0-25200 so that's OK.
then the division should be OK too.
If you are doing lots of math or want more precision, consider one of our
math coprocessors (http://www.al-williams.com/awce/pak1.htm) but honestly I
don't think you need it just for this.
Good Luck!
Al Williams
AWC
* 8 channels of PWM:
http://www.al-williams.com/awce/pak5.htm
> From: aconti@n... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Yi-fvVzvkVDfjRY5Th88-zN0VusOAwhpZmgWqZe-wjuvQcPj5Ak7N_UBCOWqJmRkPF-EEhmnJyx_t80T]aconti@n...[/url
> Sent: Thursday, May 03, 2001 5:34 PM
> Subject: [noparse][[/noparse]basicstamps] math help
> N*3600/M
> Please help
> TC
Remember,
4000 units = 1000 RPM
4001 units = less than 1000 RPM
3999 units = more than 1000 RPM
TC
units is some reciproke function of rpm
check out units = 4000 * (1000 / rpm) or rpm = 1000 * (4000 / units)
Greetings peter
use units = (4000 / sqr rpm) * (1000 / sqr rpm) due to integer math
roundings
use rpm = (1000 / sqr units) * (4000 / sqr units) ditto
Greetings peter
>>can someone please help me with a math problem? I am redesigning my
>>digital dash project. I am going to use the PULSIN command. I
>>hooked up a small project to my car and found out that at 1000 RPM
>>the stamp reads 4000 units ( 8 ms ). I am basing this on the time
>>it takes to get to one cylinder to another ( 1 - 0 - 1 transition I
>>am measuring the time of 0 ). As RPM's go up the time goes down,
>>that is where I am having the problem. If anyone has any ideas, it
>>will help.
>> Remember,
Peter Verkaik wrote:
>Hi TC,
>Greetings peter
>roundings
Hi TC,
As Peter said, it is a reciprocal
rpm = 4000000 / units
The stamp best handles that in steps, because it can't handle large
numbers directly.
One way to get good accuracy is by long division. That is, the
remainder from each division step is then used to calculate another
digit. Try this for three digits display:
' pulsin not shown,,1000,rpm-->4000 units
units=units/4 ' 1000rpm-->1000 units
rpm = 10000/units*100 + (10000//units*10/units*10) +
(10000//units*10//units*10/units)
That works mathematically down to 152 rpm. (The limitation on the
low end comes from having to multiply the remainder term times
10--the raw pulsin value will get up to 6553 at about 610 rpm--that
value/4 will get up to 6553 at about 152 rpm.)
Here the same thing as an iteration:
'pulsin not shown, 1000,rpm-->4000 units
units=units/4
rpm=10000/units
rpm1=10000//units*10
for i=0 to 1
rpm=rpm*10+(rpm1/units) ' quotient
rpm1=rpm1//units*10 ' remainder
next
' exit here with rpm=1000 when pulsin=>4000
That can be extended to double precision if necessary.
The following version kicks out digits to a display. It does not
accumulate the rpm value in a variable, so it can be carried out to
as many decimal places as you want.
rpm1 var word ' this algorithm works for rpm>152
i var nib
loop:
gosub getPulsinUnits 'not shown 1000rpm-->4000 units
units=units/4
rpm1=10000/units
debug CR,"rpm=",dec rpm1 ' kick out first quotient
rpm1=10000//units*10 ' first remainder*10
for i=0 to 5
debug dec1 (rpm1/units) ' kick out a digit
rpm1=rpm1//units*10 ' calculate remainder*10
if if i<>1 then nextrpm
debug "." ' print decimal point after i=1 digit
nextrpm
next ' exits with 3 digits printed after the decimal point
goto loop
I hope that helps. Yes, it is kind of a pain to do the reciprocal
math on the BS2!
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com/BS2index.htm <-- more BS2 math stuff
Actually 7501876/1071 = 7004.55275 so you want 7005
The error is due to the stamp's integer math.
60499/1071=56.48832 but is calculated as 56
so 56*31*4 gives 6944
which is ((6944-7005)/7005)*100%=-0.87% below real result. This is not bad
at all.
If you would calculate the 60499/X to one digit after the decimal point you
would get
60499/1071=56.5
so 56.5*31*4=7006 which is (almost) correct.
Calculate fraction*10 (i.e 0.48832*10=4.8832 -> should be rounded to 5)
(60499//1071)*10/1071=4 'integral part
(60499//1071)*10//1071=946 'rest term
calculate 0 or 1 to round off (<0.5 gives 0, >=0.5 gives 1)
946*2/1071=1
correction=(4+1)*4*31/10=62
result=6944+62=7006
Y=(60499/X*4*31)+(((60499//X*10/X)+(60499//X*10//X*2/X))*4*31/10)
Things go still wrong if 60499//X>6553 i.e. for X=50000 for example, or if
X>=60500
Using 7501875 instead of 7501876 gives you better factorization:
7501875=3*5*5*5*5*4001=1875*4001
Now you can use 4001/X*1875
Y0 = 4001/X 'integral
Y1 = 4001//X*10/X 'first decimal
Y2 = 4001//X*10//X*10/X '2nd decimal
Y3 = 4001//X*10//X*10//X*10/X '3rd decimal
R = 4001//X*10//X*10//X*10//X*2/X 'correction for 3rd decimal
Y = (Y0*1875)+(Y1*1875/10)+(Y2*1875/100)+((Y3+R)*1875/1000)
Example for X=1071 (7501875/1071=7004.55182 -> we want 7005)
4001/1071=3.73576=3.736
Y0 = 4001/1071=3
Y1 = 4001//1071*10/1071=7
Y2 = 4001//1071*10//1071*10/1071=3
Y3 = 4001//1071*10//1071*10//1071*10/1071=5
R = 4001//1071*10//1071*10//1071*10//1071*2/1071=1
Y =
(3*1875)+(7*1875/10)+(3*1875/100)+((5+1)*1875/1000)=5625+1312+56+11=7004
The important thing for factorization is: no factor must be grater than 6553
otherwise
calculating a decimal using factor*10 gives overflow.
So if a big constant can not be factorized using only factors<6554 then you
must select
the nearest big constant that does, otherwise the above method does not work
for all X.
(By the way, for X=0 there is no solution).
Hope this helps.
Greetings peter.
>N*3600/M
>Please help
>TC
Hi TC,
I had missed this question. Try this:
' compute Y=N/M*3600
N var word ' input: numerator N<32768
M var word ' denominator M<32768
Y var word ' result =N*3600/M, integer
F var word ' for computation of fractional part
J var nib ' index
main: ' demo program
for N=100 to 700 step 100 ' demo numbers
for M=1000 to 18000 step 1000
debug dec N,tab,dec M ' show inputs
gosub divide
debug tab,dec Y,CR ' show result
next
next
end
divide: ' subroutine
Y=N/M*3600 ' integer part
F=0 ' initialize
for J=15 to 0 ' 16 bits
N=N//M<<1 ' remainder*2
F.bit0(J)=N/M ' next bit
next
Y=F**3600+Y ' rescale
return
-- regards,
Thomas Tracy Allen Ph.D.
mailto:tracy@e...
http://www.emesystems.com/BS2math2.htm <-- explains how it works
The little program I posted earlier today needs a local variable in
the divide subroutine, so that the numerator can step through values
in the for-next loop in the demo. Corrected version:
' Tracy Allen @
' http://www.emesystems.com
F var word ' local var for divide routine
X var word ' local var for divide routine
J var nib ' index
for M=100 to 18100 step 2000
gosub divide
next
next
end
X=N ' local numerator
F=0 ' initialize
X=X//M<<1 ' remainder*2
F.bit0(J)=X/M ' next bit
next
return
-- regards
Tracy Allen
mailto:tracy@e...
>Nx36/(M/100) = MPH
>this is the formlua for miles per hours ( speed ). Where M = pulses
>per mile, and N = reading from the count camand, and 3600 = 60x60. I
>will try your formiua and see witch is better.
Integer division M/100 may compromise accuracy more than you want.
For example, when M=199, then M/100=1, not 1.99 or 2. Slightly
better result would come from Nx72/(M+25/50). (given that N<700,
N*72 fits in a word variable).
The method I suggested using long division is never off by more than
one, however, at the expense of a much longer calculation.
If M is a constant (is it?), you can simplify the formula greatly and
still have great accuracy.
>Also, do you know of a
>way I can convert MPH (standerd) to Km/h (metric)?
' kmph = mph * 1.60934
' stamp:
kmph = mph */ 412
' the above always rounds off low
' for better roundoff:
kmph = mph*10 */ 412 +5/10
>Thanks for the input. always looking for a better idea.
>TC
You're welcome.
-- regards,
Tracy Allen
mailto:tracy@e...
One way to get a little extra in a case like this is to use fixed point. So
to calculate M/100 you might say:
M1=M*10 ' convert to .1 units
M1=M1/100 ' do division
M1=(M1+5)/10 ' convert back to units with rounding
So if you are dividing 199/100, the steps look like this:
M1=1990
M1=19
M1=(24)/10 = 2
Which is a closer answer than 1. Of course, this assumes that M1<=6553. You
can also "round in binary"
M1=M*2 ' add 1 extra bit
M1=M1/100
M1=(M1+1)/2
M1=398
M1=3
M1=(4)/2=2
Same answer in this case and M only has to be <=32K
The long division will always be more accurate, I suspect. Of course, a
PAK-I or PAK-II would also take care of this very easily plus add much
flexibility.
Al Williams
AWC
*Connect your Stamp to the Internet:
http://www.al-williams.com/awce/netporter.htm
> From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VyNRWW_TiHyy7YDdVepl9wMLcoytFKfkJ8cwxOaMcxiWAIuefyuk1EfionYv6jhLcdZD6CMnb_PwaYa2gw]tracy@e...[/url
> Sent: Thursday, May 24, 2001 12:29 AM
> To: aconti@n...; basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] re: math help
> >Thanks Tracy, but Al helped me with it, he gave me
> >Nx36/(M/100) = MPH
> ' stamp:
> kmph = mph */ 412
> >TC
> You're welcome.
> -- regards,
> Tracy Allen
> mailto:tracy@e...
a spreadsheet. I had to round the numbers in the fields that the
Stamp would truncate.
Then I can see where the calculation fails by being too high or too
low. In one app, I had a check to see if it was under "X" and
multiply by 1,000, between "X" and "Y" multiply by 100, you get the
idea.
The resolution came out much better than I had hoped.
Hope this helps.
Dave
--- In basicstamps@au.egroups.com, "Al Williams" <alw@a...> wrote:
> Absolutely dividing M by 100 is going to cost accuracy.
point. So
> M1=1990
> M1=19
> M1=(24)/10 = 2
M1<=6553. You
> M1=M1/100
> M1=(M1+1)/2
> or
> M1=398
> M1=3
> M1=(4)/2=2
course, a
much
> flexibility.
> Regards,
> Al Williams
> AWC
> > From: Tracy Allen [noparse][[/noparse]mailto:tracy@e...]
> > To: aconti@n...; basicstamps@y...
> > >Nx36/(M/100) = MPH
pulses
60x60. I
than
and
> > ' stamp:
> > kmph = mph */ 412
> > >TC
> > You're welcome.
> > -- regards,
> > Tracy Allen
> > mailto:tracy@e...
>It is, some what. M = Pulses per mile that comes from the transmission. If I
>change tires ( either bigger or smaller ) or if I change the rear end gear
>ratio my Pulses per mile will change. So I made my program to learn what the
>pulses per mile are, and store it to the EEPROM, then read the EEPROM and
>put it in a variable ( I wish I could Make it a constant )
Well, when you have your program learn the new pulses per mile, don't
store that directly in the eeprom. Instead, calculate
X=(3600/M)*65536 and store that in the eeprom. Then the running
calculation to update your display will be much faster.
MPH=N**X
-- regards,
Tracy Allen
mailto:tracy@e...
>calculator ( 3600 / 8000 ) = 0.45 (witch the stamp can not do) then *65535
> I know what you mean "65536" ) = 29490.75. If you do it like the stamp
>3600/8000 = 1 then *65535 = 65535. I understand where you are going, You are
>trying to make my stamp faster, That is an idea that I never thought of.
>maybe this will help.
The question is, I think, how do you come up with the factor 29491
that you can store in eeprom to make your subsequent calcs faster?
x var word
y var word
z var word
i var nib
x=3600 ' X>Y
y=8000 ' y comes from your calibration measurement
z=0
for i=15 to 0
X=X//Y<<1 ' remainder*2
Z.bit0(I)=X/Y ' next bit
next
write cal0,z.byte0 ' store in eeprom
write cal1,z.byte1
The result is the number in eeprom, 29491. Simple, huh? The simple
binary division loop is calculating 3600/8000*65536 = 0.45*65536 =
29491. Then the run-time calculation is simply:
read cal0,z.byte0
read cal1,z.byte1
MPH = X ** z
which using ** is effectively calculating MPH=X*29491/65536.
29491/65536 is a close approximation to 3600/8000.
This is typical of calibration problems. If the run-time calculation
involves multiplying a variable times a fractional constant, then the
calibration step will involve calculating a constant divided by a
variable. The long division routine is perfect for this.
>Thank You for your input. Keep them coming I am enjoying the fact that the
>GURUS of programming and math are helping a newbe learn how to program. "
>Thank You"
>TC
You're welcome! Funny as it may seem, I actually enjoy these integer
math problems!
-- Tracy
>From: Tracy Allen <tracy@e...>
>Sent: Friday, May 25, 2001 12:32 AM
>Subject: Re: math help
> > >>> MPH=N*3600/M
>If I
>gear
>the
> > MPH=N**X
R = ( ( 1 / ( units * .00000075 ) ) / 4 ) * 60
using PULSIN
' PULSIN pin, 1, units
I am looking for no more then %1 of error but I am looking for less. also the
end output could be in multiplies of 10. EI 10,20,30,100,110,120 ect.
please help
thanks
aj
I'm sure Tracy will have some magic way to do this. However, one thing
to look at is using a PAK I, II, or IX coprocessor to do the math. This
gives you 32-bit floating point math and it quite easy to use from the
Stamp. See http://www.al-williams.com/pak1.htm
Good luck!
Al Williams
AWC
* 8 channels of PWM
> From: Anthony Conti [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Nss_VvKkowpriDLoiplQ6yif5L4qqpwyx4WAN4uGs8dshno80ozgSxebLA3Pi52p4as8rOdAZxbOJA]aconti@s...[/url
> Sent: Sunday, June 15, 2003 9:06 PM
> I need help on trying to find out how to do this math formula
> using the BS2p.
> using PULSIN
> for less. also the end output could be in multiplies of 10.
> please help
> thanks
> aj
> from the same email address that you subscribed. Text in the
thanks
aj
--- In basicstamps@yahoogroups.com, "Al Williams" <alw@a...> wrote:
> Hi AJ,
thing
This
the
> Good luck!
> Al Williams
> AWC
> * 8 channels of PWM
> > From: Anthony Conti [noparse][[/noparse]mailto:aconti@s...]
> > using the BS2p.
> > using PULSIN
> > please help
> > thanks
> > aj
Simplifying, I come up with:
R = 20000000/units
So one way that gives three significant figures would be
R = (20000/units * 10) + (20000//units *10 /units)
For example, suppose units=255. Then the correct answer to 5 digits
is 78431. The Stamp formula gives 784, which you would print out
with two more zeros. The best accuracy will come with pulsin
readings around 250.
There are more accurate ways to do the reciprocal.
http://www.emesystems.com/BS2math2.htm#Reciprocal
or even at full precision:
http://www.emesystems.com/BS2math6.htm
-- Tracy
>I need help on trying to find out how to do this math formula using the BS2p.
>using PULSIN
>also the end output could be in multiplies of 10. EI
>please help
>thanks
>aj
the expected range will be from 2000 to 65535.
where 2000 = units, & R = 10,000. 65535 = units, & R = 300 ( 305.1 )
also the con "4" could change to "3" at a later date
thanks
AJ
> What is the expected range of your "units"?
> R = 20000000/units
digits
> -- Tracy
using the BS2p.
> >using PULSIN
less.
> >please help
> >thanks
> >aj
X var word ' 256<=X<=65535 <-- your units in this range
Y var word ' 256<=Y<=65535 output <-- the result
J var nib ' helper variable
X=5555 ' for example
reciprocal:
J=ncd X - 8
Y=65535/X*256+(65535//X<<(8-J)/(X>>J))
Y=Y**12589+Y ' renormalize to 20000000/X
debug cr,dec X,tab, dec Y
' with X=5555, Y=3600 (correct value is 3600.36)
' with X=55555, Y=358 (correct value is 360.0036)
Your output range will be 305 to 10000. The formula works by finding
2^24/X, then renormalizing (Y=Y**12586+Y) to a numerator of 20000000.
More explanation here:
<http://www.emesystems.com/BS2math2.htm#Reciprocal>. If "4" becomes
3, it will only affect the renormalization. (Y=Y**38630+Y).
Is that enough accuracy? It will be well within 1%.
-- regards,
Tracy
>Tracy
>thanks
>AJ
>> R = 20000000/units
>digits
>> -- Tracy
>using the BS2p.
>> >using PULSIN
>less.
>> >please help
>> >thanks
>> >aj
