Al''s water analogy..
Water pressure in this case is a function ONLY of water depth. Two holes in
the bottom of a tank, assuming the same water depth above each hole, will
both be under the same water pressure, regardless of the size of the hole.
Two holes, of any size, located in the side of a tank at different depths
will exhibit different pressure. In an atmosheric-pressure system, the
pressure increases by one atmosphere (14 psi, I think) of pressure for
aproximately each 33 feet.
We now return you to your regularly scheduled program....
> From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3Cv3HQmuZxfwBu9Td6vjSlYGZxCkVPxCztrhshjpWDdgCZD7lYyMF9cL8ltwJ9L3m5Nzr7TgPKeupEVjyw]alw@a...[/url
> Sent: Thursday, May 03, 2001 10:22 AM
> Subject: RE: [noparse][[/noparse]basicstamps] Re: Al's water analogy..
> Granted, I'm known to be "bad" at pretty much anything mechanical
> so I might
> well be wrong, but it seems to me that the small hole will have more
> pressure because it has less flow. Energy will be conserved so less flow
> will turn into more pressure.
> so I might
