Al''s water analogy..
Chris
The analogy is still OK.
Think of a battery: how much current you tap, how faster it will be empty.
ECO
Sent: jeudi 3 mai 2001 15:11
Subject: [noparse][[/noparse]basicstamps] Re: Al's water analogy..
> Hey Al, Its my turn to be a smart-***.
> >If I punch a hole the size of my fist in the tank, more
> >water will flow per second, but it won't be under so much pressure
> Initially the pressure will be the same for both holes, as they would
> presumably be at the same depth from the surface of the water, the pressure
> will reduce faster for the larger hole.
> Sometimes water analogies can turn to rubbish, but like you said, if it gets
> some work done....
> Chris
ECO
> some work done....
> Chris
