Book Recomnedation (+/-)
<major snippage>
I was not going to reply to the positive-negative thing
but I feel I must put in my 1 cent worth (I dont have 2 cents).
Anymore I don't care which direction it goes.
There was a time when I HAD to know every detail about
how something works and I would not advance further until
the mystery at hand was solved. Looking back in hindsight
I found this to be a happerance to my advancement.
I used to program exclusively in assembly or machine code.
I had complete control over what was going on. Then as the
C language came out I was totally annoyed that I did not
know the underlying machine code for the printf function.
Though the function worked fine, if anything were to go wrong,
I wanted to know the complete workings of the function so I
could fix it. Today I use functions without thinking twice.
I investigate when something isnt working, but I dont bother
wonder WHY something works, it just works or it dont.
It's the same with electronics. I know what an op amp is and
I know how to get it to work from me mostly learning by circuit
examples. I never learned all that extreme math that is taught in
the op amp books because that would turn me off to the fun of
electronics. I mean a hobby is supposed to be fun isnt it?
I just know that I have an audio signal that I want to amplify.
I look at a sample circuit, build something close, scope it out
and tada amplified signal! I beleive too much strict adhersion to
engineering rules depletes inventive innovation.
I've smoked my share of parts but what a great teacher!
I think it is even possible to use a matrix of 555's as
a stove burner!
Anyway, once you did decide to follow one convention or the other
of the positive/negative delima, someone would come along and offer
you the 'ether' theory of electronics and you would have to abandon
your beliefs anyway!
I hope your wanting to be more technical in electronics does
not take away from the excitement and fun of it.
Bandit
If you understand, things are just as they are.
If you do not understand, things are just as they are.
a stove burner!
Bandit
