Encasing in resin....
Believe it or not this is stamp related......
For the advanced electronics gang....
In your opinion....Is there any problem with encasing completed circuits
in polyester resin?
The final product needs to be tamperproof and very moisture resistant
and it seemed like this could be a very good alternative....
Any potential problems with components??
Thanks!!
Rus
Bones
"Ghoul-Will Ambassador to the Boneyard"
Atrophies - Ghoulishly Original Awards & Trophies
http://www.bluedestiny.com/Atrophies/
SpiderBucky & SpiderThrifty - Boney Superheroes
http://www.bluedestiny.com/SpiderBucky/
Keeper of the Bucky-n-Thrifty Flame
http://www.boneyardbargains.com/
"my mind wanders....I'm just along for the ride"
in polyester resin?
Thanks!!
Rus
Bones
Flexane is flexible and we used to use it like coffee around here when we
used to build instruments that went in the water. If you want to pot with
something hard they make that stuff too. Years ago we used to use a hard
plastic potting compound but I can't remember the name. It was by Hysol
which was bought by Dexter if I recall. Look at
http://www.dexelec.com/html/electronic_products_-_dexter_h.html
You want something with very low conductivity and also something that
doesn't generate very hot temperatures when curing. Shrinking is also a
problem in some cases.
We used to buy that stuff by the drum. For small runs look at
http://www.mgchemicals.com/products/832b.html (about $100 if memory serves).
At high frequencies the dielectric constant of the compound can become
important. Also, don't plan on getting back inside. Usually, once they are
potted, they are in for good. When I worked for Motorola we used to
decapsulate plastic parts, but it required a mill, a hot plate, fuming
Nitric acid, and a lot of practice and patience.
Al Williams
AWC
* Expand your Stamp I/O: http://www.al-williams.com/awce/pak3.htm
> From: Rus Hardy [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=B_5r5UKkt3jWYdixZ8x0H4ECr2P9EB8R7mXebaZ-tloVeDA7NjS2wkNni4wzzaMG3Eu9egmKqIxMWdoPSvtL]rushardy@m...[/url
> Sent: Wednesday, May 02, 2001 12:26 PM
> To: Stamp Group
> Subject: [noparse][[/noparse]basicstamps] Encasing in resin....
> in polyester resin?
> Thanks!!
> Rus
> Bones
(large volumes and accelerated resisn) may reach at 180 degrees celsius.
Many components may not resist. Epoxi adhesives like normal Araldite
(24h) with slow curing time is more recomended.
ACJacques
> in polyester resin?
> Thanks!!
> Rus
> Bones
that some epoxies might weaken or damage the insulation around a wire
due to chemicals in the epoxy. Because of this I would use some sort
of plug. i.e. SIP HEADERS: If I remember right Digi-Key has a nice
AUGAT breakaway SIP STRIP with male on one side female on the other
which makes for nice customized connectors.
>The problem may be the curing temperatureof poliester. In some cases
>ACJacques
> > in polyester resin?
> > Thanks!!
> > Rus
Beau Schwabe IC Mask Designer
National Semiconductor Wired Communications Division
500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
We have run in to problems with both epoxies and resins trapping moisture
as they cured. Not a problem for most circuits, but they can cause
inference (leakage currents) with very high impedance inputs.
>in polyester resin?
>Thanks!!
>Rus
_________________________________
Mike Walsh
walsh@i...
This is exactly what I was looking for! Thank you for the links.
Rus
Al Williams wrote:
> There are several compounds especially for this "potting".
> Regards,
> Al Williams
> AWC
> > From: Rus Hardy [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7KvV6mkFN095Ocq-Qg6F3KAEACfcdPxUq3dsciFDmPIgGb4CoKOl8T9cTx0U6hWZUNcTqVEPjwfMdrgtUvC9]rushardy@m...[/url
> > To: Stamp Group
> > in polyester resin?
> > Thanks!!
> > Rus
Bones
will be subjected to any temperature extremes because the resin will
expand and shrink and could break components that it seeped into or
around.
also, if the resin expands while it solidifies you could have a problem.
I'd say as long as it has a bit of give you should be ok. just make sure
to put all your cables through a strain relief inside the resin, so
there won't be any stress on connections.
the last thing you need is a bad connection inside there
Jason
> in polyester resin?
> Thanks!!
> Rus
> Bones
_______________________________________________
Jason Lavoie
jlavoie@e...
jlavoie@o...
ICQ#:10604243
Electrical Engineering III, Carleton University
