component suggestion
Hello. I am a beginner in electronics and I would like your
suggestion on a component concerning the BS2 and a different circuit
I am trying to run off of the stamp. The BS2 outputs a positive 5
volts on all of it's pins and has a common negative. The circuit I am
trying to run has a positive common instead and isn't compatible with
the BS2. Is there a special electronic component that can change that
and make them work together (other than a relay)? Thanks very much.
