Transformer
Hi all,
Dose any one know where I might find a step-up Transformer. I nead it
to take a 12V input and have around a 30V output. I am going to use a
PWM to control the output. Please Help
TC
TC
>Thanks,
>TC
I also have a need for a voltage transformer to take a 75 kHz 5V pulse
train up to about 200V at very little current. Any suggestions? Thanks a lot!
Steve
Steve Roberts: sroberts@s...
Transformers are97%efficient, so if youhave 12 V and need 30, a 3:1
ratio will render 36V (approx) so just put a few less turns for 30 V.
What are you wanting to drive with the 30V?
Doug
> From: Stephen Roberts <sroberts@s...>
> Date: Sat, 28 Apr 2001 10:47:42 -0700
> Reply-to: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] Re: Transformer
> >Hi all,
> >Thanks,
> >TC
> Steve
>Steve
Steve,
At that frequency regular AC transformers used for
power supplies won't work, even audio transformers
are out of range. Most transformer laminations
are silicon steel and limited to low frequency pulses,
they just cant magnetize and demagnetize as fast
as you need.
A ferrite torrid core will work. There are many different
types of ferrite materials according to the frequency.
You'll have to select one for 75khz range, or one that
can magnetize and demagnetize at 75 KHz without
saturation of the core, the point where its no longer
a changing magnetic field.
Simply wind the core with the appropriate turns ratio
which looks like 40 to 1. You have to supply enough
primary turns to keep the core just below the saturation
point. The secondary turns is 40 times the primary
turns.You may need to use a resistor on the 5 volt or
primary side, depending on its DC resistance, or you
run the risk of shorting out your input driver element,
gate or transistor when it turns on.
Better yet, just buy a pulse transformer and miss all
the fun of winding torrid cores! IT AIN'T EASY!!
Good Luck,
Greg
There's no rule that says you have to use a toroid core for jobs like this.
EE or EI cores with fitted bobbins make the job much easier. By the way,
salvaged cores from TV horizontal output transformers should work well at
75KHz. They normally operate at the 5th harmonic of the H scan rate
(~15KHz)...
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
>(~15KHz)...
You're absolutely right. I was also thinking that a small transformer from
a 5 volt 1 amp switching power supply may work in reverse too.
Greg
On Sat, 28 Apr 2001 01:24:54 -0000 aconti@n... writes:
> Hi all,
> it
> a
> Thanks,
> TC
