BS2 External Memory
Hi all,
I'm currently running an app that logs data to external serial memory.
The chip that I'm using is the 24LC256. Is there a different memory
that I can use with the stamp of equal or higher storage capacity,
that has faster read and write access times? If so, are there any
example circuits around.
I don't mind if the memory is serial or otherwise, I only use serial
at the moment because there were heaps of examples available, my only
requirements are high speed access and large storage space.
All ideas appreciated.
Simon
Simon
>Thanks,
The 24LC256 is an i2c memory, and that must mean, if you have a
vanilla BS2, that you are bit-banging the code for the i2c protocol.
Or you have an exteral protocol converter. ???? That is very slow.
The BS2P has support for i2c built in, so access to the i2c memory
would be very fast, and a "no-brainer" for code.
An alternative faster memory is the AT25256 (atmel), which is SPI
3-wire. The vanilla BS2 and the BS2e and BS2SX do support SPI, so it
does not take nearly as much code as the 24LC256. If you are using
the BS2P, it is a tossup.
There are much faster serial memories available, for digital cameras,
voice recorders etc. They include large multiple RAM buffers so that
data can be streamed in continuously at very high rates. However,
the Stamp is way too slow to attain those rates.
-- regards,
Tracy Allen
http://www.emesystems.com
Date: Thu, 26 Apr 2001 06:29:39 -0000
I sent message below out March 8th and there was no reply..
I'm still interested and your need may be met by some
Ramtron part/parts.... check their site...
I wonder if anyone has used a Ramtron non-volatile
memory in a BS2?
They have an FM24CL16 that is quite similar to the
24LC16B Microchip unit I have in my BS2 but is rated
for high speed writing and a trillion write cycles
- 10 year retention [noparse][[/noparse]24LC16B rated about 1 million and
200 years retention]. In any case these Ramtron units
could perhaps be used with the I2C bus on the BS2p.
Data sheet available at www.ramtron.com
________________________________________________________________
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
> -- regards,
> Tracy Allen
Really? How to do I use it on a BS2?
> >The vanilla BS2 and the BS2e and BS2SX do support SPI...
> > -- regards,
> > Tracy Allen
>Check the manual under Shiftin and Shiftout. Make sure you carefully check
the parameters in the datasheet for the particular device you are using.
Specifically, the MSB/LSB and PRE/POST sub-parameters in the respective Shift
instructions, are MOST important. Device examples are shown in the manual.
The PBASIC Stamp Manual is available, free for the download, from the Parallax
web site [noparse][[/noparse] http://www.parallaxinc.com ] in the Download section.
If you have trouble with a given device. just check back here with:
1) Name of the manufacturer
2) Type of device and
3) Specific part number (including suffixes if appropriate)
That should be enough to begin troubleshooting any problems you might
encounter.
Bruce Bates
writes:
> At 5/4/2001 Friday 09:11 PM, agarb@j... promulgated:
> > > -- regards,
> > > Tracy Allen
> carefully check the parameters in the datasheet for the particular
device you are
> using. Specifically, the MSB/LSB and PRE/POST sub-parameters in the
> respective Shift instructions, are MOST important. Device examples are
shown in the
> manual.
Thanks. I didn't realize you used Shiftin/Shiftout to do this.
Aaron
