Junk transmission
I also sometimes have some "junk" characters in the Stamp debug screen.
I dont know the reason but I believe this bug comes from debug program
itself and not from Stamp.
ACJacques
the_coin_guy@y... wrote:
> Hi all!
> Just a quickie. I am using the rentron plans to make a BASIC stamp
> wireless transmission set. I am, however, using two BS2's. Anyways, I
> have the transmitter(TWS-434) sending a byte that holds the number
> "19". Everytime I start to send the data to the receiver for debugging
> on the stamp debug screen, I get the number 19...but I also get a
> whole bunch of different "junk" numbers with it. Why is this? Any
> reasons?
> Thanks,
> Corey C.
ACJacques
> Hi all!
> reasons?
> Thanks,
> Corey C.
with Stamp.
ACJacques
> Are you doing this wirelessly?
> > ACJacques
> > > Hi all!
> > > reasons?
> > > Thanks,
> > > Corey C.
experimented the newest.
ACJacques
Rodent wrote:
> One thing of note is that the debug "screen" appears to be a chunk of memory
> that is reused. If you send a program to the Stamp with a debug statement,
> it apparently clears the memory, opens a debug window and stuff is displayed
> as it happens. If you send the program to the Stamp again without closing
> the old debug window, you may see stuff displayed from the last program run.
> I'm thinking the memory is not cleared. This drove me crazy at first. The
> fix is to always close the debug window before sending code to the Stamp.
> I know this for sure about STAMPW.EXE v 1.099 or whatever it was --
> hopefully v 1.1 does not have the same problem.
reasons?
Corey C.
> ACJacques
> > Hi all!
> > reasons?
> > Thanks,
> > Corey C.
