Let''s Talk Solid State Relays! (was: Newbie Advice/Solenoid Sequencing)
These are actually larger 10-amp per contact relays. We switched fueling
equipment on and off with them. They had 110-volt coils and were driven with
a triac and an opto-isolator. You could probably find 12-volt or 5-volt
models as well and drive them directly with a transistor.
You may be thinking about the smaller clear DIP relays you find at Radio
Shack.
> I assume you are refering to the clear plastic cube relays?
> This is what I'm currently using in my small analogue circuit. So you
> are confirming my initial plan of small relay linked to a larger relay
> for the 120VAC?
> What would be the specs for the smaller intitial relay (the one powered
> off of a transitor)?
Shack.
> for the 120VAC?
