Let''s Talk Solid State Relays! (was: Newbie Advice/Solenoid Sequencing)
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
Hi ya Rodent,
> Solid-state relays generate heat, while a regular relay does not (except for
> the coil). They also generally do not turn completely off -- you will have a
> little bit of leakage, which could pose a shock hazzard. The benefit to
> solid-state relays is they do not have contacts that spark, which would be
> bad in a hazzardous environment. I would find some good quality plug-in
> relays and sockets and use them. You could even get some smaller double-pole
> relays and pair up the contacts to increase the load capacity. We used the
> small, plug-in "ice-cube" relays on our equipment with no problem.
I assume you are refering to the clear plastic cube relays?
This is what I'm currently using in my small analogue circuit. So you
are confirming my initial plan of small relay linked to a larger relay
for the 120VAC?
What would be the specs for the smaller intitial relay (the one powered
off of a transitor)?
Thanks.
Cheers,
-Neal
Hi ya Rodent,
for the 120VAC?
Thanks.
Cheers,
-Neal
