Pak-III help
Has any one worked with the AWC Pak-III? if so can you please give me
a simple code for A BS2, so I may see what I am getting in to, Also
how good is it's COUNT camand (can it go up to 1500 ms), And can it
do many things at once,like 2 count camands.
thanks
TC
thanks
TC
Like the Stamp, the PAK only does one thing at a time (that's not true of
all the PAKs, but it for the PAK-III). However, the PAK can do something at
the same time that the Stamp is doing something else. So you could have the
PAK do one count while the Stamp does the other.
As for the code, try the example on the disk.
The IOUTIL.BS2 file is a library of calls you can use. Where it says:
' Test Code - Replace with your own
and down to
' End of test code
You can put your own code in.
A gosub to XCOUNT will do the COUNT command. You have to set the xtmp and xA
variables.
xtmp is the pin number (0-7) and xA is the time period in 8uS units that you
want to count. The PAK will return a zero byte to indicate that it completed
the operation and then the 16-bit count. The XCOUNT subroutine handles that
for you by setting xoutvalue with the count.
So if you put this code in the "Test" section of IOUTIL.BS2 you should be OK
(assuming you want to count pin 0 of the PAK[noparse]:)[/noparse]:
doitagain:
xtmp=0
xA=10000 ' 80000uS or 80mS
gosub XCount
debug ?xoutvalue
goto doitagain
You might also study SIMPLE.BS2.
Hope that helps.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
> From: aconti@n... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9oKggX951RS3aPJcw7RjVUhJ2O62PowCZw8YAIZ4Ck_oqZ5S7GUfoq1b5pytHM6QYYzJKM8pdpG-Qw]aconti@n...[/url
> Sent: Tuesday, April 24, 2001 5:48 PM
> Subject: [noparse][[/noparse]basicstamps] Pak-III help
> thanks
> TC
time? my stamp will be working on other things, like controling the
display.
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> Hi TC,
true of
something at
have the
says:
> and down to
> ' End of test code
xtmp and xA
> variables.
that you
completed
handles that
should be OK
> doitagain:
> xtmp=0
> gosub XCount
> debug ?xoutvalue
> goto doitagain
> Hope that helps.
> Al Williams
> AWC
microcontroller:
> > From: aconti@n... [noparse][[/noparse]mailto:aconti@n...]
> > To: basicstamps@y...
give me
Also
it
> > thanks
> > TC
measure pulse widths and counts on 8 channels at once. Plus you get a timer
tick.
You can use this chip to read RC times, tachometers, anything that you need
to time or count pulses.
http://www.al-williams.com/awce/pak7.htm
> From: aconti@n... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BfI6e0JZn6jKufnjBJ5Zk137jNDoKZDb-gZLXrvMH1kpq5v6LB4HPjs9YBWY0ENs3EPgW3mkuA]aconti@n...[/url
> Sent: Tuesday, April 24, 2001 6:07 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Pak-III help
> well would the Pak-IV work beter to read 2 count camand at the same
> display.
> > Hi TC,
> true of
> something at
> have the
> says:
> > and down to
> > ' End of test code
> xtmp and xA
> > variables.
> that you
> completed
> handles that
> should be OK
> > doitagain:
> > xtmp=0
> > gosub XCount
> > debug ?xoutvalue
> > goto doitagain
> > Hope that helps.
> > Al Williams
> > AWC
> microcontroller:
> give me
> Also
> it
> > > thanks
> > > TC
thanks
TC
> No, if you want to read 8 counts at one time, check out a PAK-VII.
You can
a timer
> tick.
you need
same
the
> > display.
> > > Hi TC,
not
> > true of
> > something at
could
> > have the
> > says:
> > > and down to
> > > ' End of test code
> > xtmp and xA
> > > variables.
units
> > that you
it
> > completed
> > handles that
> > should be OK
> > > doitagain:
> > > xtmp=0
> > > gosub XCount
> > > debug ?xoutvalue
> > > goto doitagain
> > > Hope that helps.
> > > Al Williams
> > > AWC
> > microcontroller:
> > give me
> > Also
can
> > it
> > > > thanks
> > > > TC
