VB Interface
Has anyone used this VB interface to run the BS2? :
http://www.picobay.com/VB6.html
I tried it, and I get the error message, "Invalid com port or port
already in use." I do not understand this. The stamp works with the
debug screen and everything...so why not with this program. All the
setting are the same.
Any help?
Corey
Any help?
Corey
You don't happen to have any Palm Pilot Software on your computer or
anything else that may tie up your serial port ?
Regards
Dean
Sent: Monday, April 23, 2001 9:16 PM
Subject: [noparse][[/noparse]basicstamps] VB Interface
> Hi,
> Any help?
> Thanks,
> Corey
I have not used the VB interface that you referenced, but have written
several of my own. My experience with the MSCOMM control has taught me
that it is extremely picky. You must make sure that the com port it is
trying to use is not already in use by another app. I have found that
the only way to get it to reliably work is by including a little
subroutine to test the com port before MSCOMM tries to open it (here is
a little pcode snippet):
IF com1 = open THEN
Close com1
End IF
gave an error, you can assume it either does not exist or is in use by
another device.
> IF com1 = open THEN
> Close com1
> End IF
port is free?
--- In basicstamps@y..., "Dean Stevenson" <dean@i...> wrote:
> Hi ,
> Regards
> Dean
> From: <the_coin_guy@y...>
> To: <basicstamps@y...>
> > Hi,
> > Any help?
> > Thanks,
> > Corey
Thanks for the info. This program, instead of having to cut the ATN
line, has the DTR disabled in the MSCOMM control....could this be a
problem, or is this a proven way of having it work...?
Corey C.
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> Yup, except I would do an ON ERROR routine, and if trying to open
the port
> another device.
taught me
it is
(here is
> > IF com1 = open THEN
> > Close com1
> > End IF
the_coin_guy@yahoo.com writes:
port is free?
If you have DEBUG statements in your program and the Stamp editor running,
the port will get tied up. ·Try to shut down the editor before running your
VB app.
-- Jon Williams
-- Dallas, TX
[/font]
