BS2 adxl202 and PICS
Has any of you ever used an ADXL202 accelerometer to measure speed
(velocity) variables using BS2(or picbasicpro).
You input will be appreciated
acceleration (g forces) - a speed change, or tilt over gravity axis.
This is very straightforward as you use only the PULSIN command and BS2
connection is with 1 wire + gnd.
ACJacques
