multiple LTC1298
[font=arial,helvetica]Hi everyone,
I would like to use multiple LTC1298 ADC's with one BS2. I am thinking I only
would need one additional line for each extra ADC I add. Is there any
problems with doing something like this? ·I want to use two right now, but
will eventualy have 3. I am not so hot with code for adding devices, mostly I
use code snippets I find and start working my way thru them. Any info or
insights would be most appreciated.
Thanx,
[/font]
Thanx,
[/font]
LTC1294, etc?
only would need one additional line for each extra ADC I add. Is there any
problems with doing something like this? I want to use two right now, but
I use code snippets I find and start working my way thru them. Any info or
insights would be most appreciated.<
Mike Hardwick, for Decade Engineering -- <http://www.decadenet.com>
Manufacturer of the famous BOB-II Serial Video Text Display Module!
decade@worldnet.att.net writes:
LTC1294, etc?
I would definitly go that route in the future. On this project I have already
had 6 boards made and they are to accomodate the ltc 1298, what happened was
all of a sudden I found out I needed a bunch more ADC inputs then i had
counted on. This project has become a nightmare, I told my dad I could have
some equipment made for the company he works for, now the deadline is here
and I still am trying to get the first prototype finished. I have not slept
comfortably in weeks [noparse]:([/noparse]
I am hoping on trying out the prototype tonight, so far there has been all
sorts of things going wrong. I screwed up on a few of boards and had to slice
and jump traces. there are portions that I have not even tryed out yet. The
fun just never stops [noparse];)[/noparse]
back to work for me
[/font]
I would have been nice if the converter had at least two more
channels.
Does any one no how long it takes to read the two channels????
>From: electronguy@a...
>Reply-To: basicstamps@yahoogroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] multiple LTC1298
>Date: Thu, 19 Apr 2001 23:25:15 EDT
>In a message dated 4/19/01 7:19:17 PM Pacific Daylight Time,
>decade@w... writes:
> > Any particular reason you don't want to use 8-channel ADCs such as
>LTC1290,
> > LTC1294, etc?
>already
>was
>slice
>back to work for me
_________________________________________________________________________
Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com.
a 24 pin STAMP and has 8 8-bit ADC channnels, 8 extra I/O ports, RTC
with built-in battery backup, up to 256k EEPROM, built-in 3-wire and
I2C bus (with integrated pull-up resistors) and a programming port.
Since you've already had some boards made, it most likely won't work
with this project, but it could help on a future project. It would
give you the extra ADC channels and give you some extra I/O.
Details of the design are at: www.high-
techgarage.com/products/supermax.php if you are interested.
Good luck with your project!
-- Jeff
--{ www.high-techgarage.com }--
--{ Why park your STAMP anywhere else? }--
> decade@w... writes:
as LTC1290,
> > LTC1294, etc?
have already
happened was
had
could have
is here
not slept
been all
had to slice
yet. The
> back to work for me
the LTC1298?????????
-Steve
At 01:06 PM 04/23/2001, you wrote:
>How long does it take to read the two channels of
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>From: sargent@shout.net
>Date: Tue, 24 Apr 2001 20:15:27 -0500
>Which stamp are you using?
>-Steve
At 12:53 PM 04/25/2001, you wrote:
> BS2-OEM
> >From: sargent@s... >Reply-To: basicstamps@yahoogroups.com >To:
>basicstamps@yahoogroups.com >Subject: Re: [noparse][[/noparse]basicstamps] multiple LTC1298
>>Date: Tue, 24 Apr 2001 20:15:27 -0500 > >Which stamp are you using? >
>>-Steve > > >At 01:06 PM 04/23/2001, you wrote: >> >>How long does it
>take to read the two channels of >>the LTC1298?????????
>http://www.hotmail.com. >> >> >> >> >>Your use of Yahoo! Groups is
>subject to http://docs.yahoo.com/info/terms/ >> >> > > > >Your use of
>Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
