BS2 input conditioning
Hello,
I was reading, in one of the PDF files, about methods for
conditioning of digital inputs for the stamps. I have built a circuit
(Breadboard) for use in my truck. Four of the BS2 I/O's are used as
inputs to monitor changes in the 12V signal (ie ON=12V, OFF=0V). The
PDF showed that for this input type, an optocoupler (4N35, I
believe), should be used. I chose to use a 2N3904 and a couple of
resistors such that the 12V input switches on the transistor which
then passes the 5V VDD signal level to the stamp. This however,
requires one transistor and 3 resistors for each input pin in my
design - but it works great.
In an effort to minimize parts and simplify my PCB, I want to use
one resistor and a 4.7V zener diode to condition the ~14V input down
to 4.7V. This would allow the normal voltage fluctuations in the
trucks 12V system while maintaining the BS2 input level at 4.7V. In
testing, I have found that the BS2 will consistently recognize 4.7V
as a "high".
The only downside I can see, and finally the point of my post, is
that if the zener were to ever fail open circuited, the stamp would
be passed the full voltage of ~ 14VDC. This is an unlikely failure,
but if it occurred, would the stamp be damaged ?
Regards, John.
as a "high".
Regards, John.
Two "Stamp Savers":
1) Use a 22K resistor in series with the Stamp input pin. This alone should
save the Stamp from 14 volt input.
2) Connect 2-4.7 volt zeners in parallel. If one zener fails, the second
will take over. The probability of both failing is miniscule.
Ray McArthur
regulator as conditioning device for pin input. It is cheap,reliable,
single device, and with wide range input.
ACJacques
john_trinca@h... wrote:
> Hello,
> as a "high".
> Regards, John.
stamp pin ?
Charlie Bachetti
--- In basicstamps@y..., "Ray McArthur" <rjmca@u...> wrote:
> Yes ... it would probably kill the stamp input pin that went
overvoltage.
> Two "Stamp Savers":
alone should
second
> Ray McArthur
is
would
failure,
>as a "high".
Good choice of zener voltage. A stamp will recognize a logic 1 for any
voltage above about 1.4 Vdc.
I would use an input series resistor of 10k or so. In addition, you need
to consider how you see a logic 0. Does the 14V input actually go to
ground or does it float. An additional 10k resistor in parallel with the
zener eliminates the floating input problem and also improves your noise
margin.
You can eliminate the zener if your input voltage is well defined. If you
know that it can't go above 16 Vdc, leave the series resistor at 10k and
make the shunt resistor 3.3k . That protects you for input voltages up to
about 20 Vdc and still works with voltages down to about 6 Vdc. Your
nominal input voltage is 14V - lots of headroom.
I use that exact technique in my high volume products, except that I use
10k and 2.4k since my nominal input is 17 Vdc.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 17 years of Engineering Innovation (1984 - 2001)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
> stamp pin ?
No. The idea is that if one zener opens, the second one takes over.
Usually, the zeners are not perfectly matched for breakdown voltage, so one
will take all or most of the current. If it fails, the second zener will
regulate. I guess if I were doing the job, Dwayne Reid's approach would be
preferable, since it uses cheaper parts and still protects the Stamp.
Ray McArthur
That's perfect. The truck voltage is fairly stable and I think the
two resistor application would be ideal for my purposes. I didn't
realize that the stamp would still "see" a "high" even down at 1.4 V.
Thanks, John.
If you
10k and
voltages up to
Your
I use
> dwayne
>Dwayne,
>Thanks, John.
I don't think that it is in the specs, but, yeah, the original stamp 1
does. I assume that all the other PIC based stamps do the same.
Since this is going on a vehicle, I'd probably do it slightly
differently. This takes 3 resistors instead of 2. Input shunt resistor:
4k7. Series resistor: 100k. Output shunt resistor: 33k.
What I've done is 2 things: scale the divider network to use higher value
resistors. This limits input current if an overvoltage situation
occurs. Second, provide a low value input shunt resistor to minimise the
effects of leakage current being seen as a false logic HI.
The reason for scaling the input divider is to deal with load dump
transients. On a 12V vehicle, you can expect load dump transients up to
about 40Vdc lasting for as long as 100 msec. To the stamp, this looks like
a 10Vdc input with a source impedance of about 24k which translates into a
input clamp current of about 200 uA - well within the input clamp ratings
on the PIC.
dwayne
