beam break detector — Parallax Forums
beam break detector
edited 2001-04-17 12:13 in General Discussion
Hi List:
This is my first posting to the list. I am an occasional electronics
hobbyist (and Ham - AA4YH) from Cary, North Carolina. I bought a BS-1 a few
years ago and fooled around with it, making some LEDs blink, etc.
I now have a real project that I'm trying to design. The target
microcontroller is still undetermined, but I'm leaning toward the OOPIC (I'm
a computer scientist by profession, and like the programming paradigm of the
OOPIC).
Here's what I'd like the advice of the list on: I am designing a race timer
for timing flyball races. Flyball is a relay race for dogs - they have to
jump four hurdles, and press the pedal of a spring-loaded box, which
releases a tennis ball, then return with the tennis ball, across the four
hurdles; repeat with next dog.
I want to time the start/stop with a beam break detector. Since the dogs
that run these races can be any size, my plan is to use a total of four
beam-break detectors in the same vertical plane at four or six inch vertical
spacing. I'm thinking infrared LEDs and phototransistors. What I'd ideally
like to do is to use only one I/O line to detect whether any of the four
beams have been broken. I don't need to know which one was broken, only that
one of them was broken.
I suppose I could build something like a four-input OR circuit, but I'm
wondering if there isn't some way to create a serial chain of these
detectors, and just detect a high-to-low (or low-to-high) transition if any
beam is broken.
Does this make sense? Any thoughts? Any thoughts on my choice of
microcontroller or LED/phototransistor combination?
Thanks folks. This is a great list!
Michael Clark
    edited 2001-04-16 20:33
    Here is a link to a schematic that will detect a break in a beam from a
    common laser pointer keychain (~650nm). It worked very well for me, but my
    application did not require exact timing like you might need in a racing
    application such as yours. I have not checked the delay between beam
    breaking and the logic level output changing, it seems instant but it could
    be slow for you.
    http://home.earthlink.net/~dankgus/SCHEMATICS/photocell.bmp
    --Dan
    To: "Basicstamps List" <basicstamps@yahoogroups.com>
    Sent: Monday, April 16, 2001 5:43 AM
    Subject: [noparse][[/noparse]basicstamps] beam break detector
    > Hi List:
    few
    (I'm
    the
    > OOPIC).
    timer
    vertical
    that
    any
    > beam is broken.
    > Michael Clark
    edited 2001-04-16 22:40
    Hi Michael,
    You might simply connect each of the four led/detector pairs through
    a silicon diode, thus configuring a four input "or" that way. No TITLE chip
    needed. Whenever any of the four register a "Hit" you'll get a signal,
    either hi or lo, depending upon your circuit configuration. You can poll
    this this point in a looping routing with the stamp and branch to a
    subroutine to service this, such as a timer or whatever you like.
    Hope this helps,
    Russ
    To: Basicstamps List <basicstamps@yahoogroups.com>
    Sent: Monday, April 16, 2001 8:43 AM
    | Hi List:
    | OOPIC).
    | beam is broken.
    | Michael Clark
    edited 2001-04-17 00:36
    Russ - thanks for your reply. I'm not certain that I understand exactly
    what you are describing. Should I 1) connect all outputs to a single diode,
    or 2) connect each output to a different diode, with diode outputs tied
    together?
    From: Russ Bassani [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=L7ZJu94I1ns7Vc-i2qGPV-Lo-QyoNDVCmw47Ei90pXkmq7qaqI9rY9S5y87KGzctd_3gMk3NODRt9XUmYw]RussBassani@a...[/url
    Sent: Monday, April 16, 2001 5:40 PM
    Subject: Re: [noparse][[/noparse]basicstamps] beam break detector
    Hi Michael,
    Hope this helps,
    Russ
    | Hi List:
    few
    (I'm
    the
    | OOPIC).
    timer
    vertical
    that
    any
    | beam is broken.
    | Michael Clark
    edited 2001-04-17 00:39
    Dan - thanks for the link to the schematic. I hadn't thought of using a
    laser pointer as a light source, but it would certainly alleviate any
    concern about distance between emitter and detector that I have.
    Michael
    From: Dan Gustafson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z5WnN-8qUMinYNXIDlLJeBW8weMKGc1iGqO1G3uuLC0udi7jHcSYqJqm6fTi5E5Zd5Ga87LOlT80u9hVFSAc]dankgus@e...[/url
    Sent: Monday, April 16, 2001 3:34 PM
    be slow for you.
    --Dan
    > Hi List:
    few
    (I'm
    the
    > OOPIC).
    timer
    vertical
    that
    any
    > beam is broken.
    > Michael Clark
    Hi Michael,
    What I meant was to use the I/R beams (4) as you described, but to
    simply connect their outputs in parallel with each other, each through a
    diode, so that if any of them were to register a dog "hit", that beam sensor
    would pull down your signal line through its diode, to stop your counter.
    The diodes would provide some isolation between the I/R sensors, since
    we don't know the sensor's output configuration, and to simply connect all
    four of them together might cause problems, the diodes are a way to do
    it more safely.
    Russ
    Sent: Monday, April 16, 2001 7:36 PM
    Subject: RE: [noparse][[/noparse]basicstamps] beam break detector
    | together?
    | From: Russ Bassani [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3D9Rd8TbQ_3B3FfLKWmUeMq7LZX9PyEs7tDi4K0aPCDro44CIpeETSCu1lDQo-O3ZgHg3khPMT_KjjVUbu4]RussBassani@a...[/url
    | Hi Michael,
    | Hope this helps,
    | Russ
    | | Hi List:
    | few
    | (I'm
    | the
    | | OOPIC).
    | timer
    | vertical
    | that
    | any
    | | beam is broken.
    | | Michael Clark
