LED''s In Series.....
I have a question about wiring LED's in series. LED Requirements:
Voltage Drop of 2.4V at 20mA. Supply Voltage: 12VDC. I'd like to put four
in series using just one current limiting resistor. I understand that I
should add-up the total voltage drop for the four in series, but my question
is, should I divide this by 20mA or by 80mA to calculate the resistor value?
In other words should the series be allowed 20mA total or should I figure
20mA for each LED?
2.4V x 4LED's = 9.6V Total Voltage Drop.
12V - 9.6V = 2.4V Remaining.
2.4V / 20mA = 120 Ohm Resistor?
OR
2.4V / 80mA = 30 Ohm Resistor?
As always, thank you for your time and consideration - especially with the
"rookie" questions.
Tim
20mA for each LED?
OR
"rookie" questions.
Tim
