Ok, I got it to work ... yay! Howeever, now, I want to send a msg
from the computer to the transceiver... the serial data out pin (pin
3 on serial port) is always high though when no data is sent. When i
connect that pin to the transceiver input (pin 1 - TX), the TX is
always on then because of this voltage high from pin 3 of the serial
port... and then i can't receive anything from the receiver... does
anyone know if i can keep that pin (pin 3 on serial) low always, and
when it transmits it will transmit data... I tried just puting
outportb(0) or something like that..but, it would still add the start
bits, which screwed things up...
I'm thinking this might be normal. Have you already hooked up the
transceiver, and verified it doesn't work? Or did you just hook up a
voltmeter, see the voltage and think "That's not right!"?
It's been a while since I worked with asynch at this level, but I'll give it
a try. When the line is idle, the line is kept at mark level.. The start of
a data byte is signaled by a start bit at space level. The start bit is
followed by the defined number of data bits from LSB to MSB, the parity bit
if defined, and the defined number of stop bits, again at mark level. Mark
level, according to the document I looked at at http://www.techfest.com/networking/wan/async.htm says that "MARK condition
is normally established by a NEGATIVE voltage on the interface." I'm
guessing this voltage is probably what you're seeing.
> Hi again..
> Thanks
> Debu
Yes negative at RS232 levels and high at the TTL side. 0 if using no driver.
Note some modules like the MING are simple on/off so should be a low input in
the
idle state.
> Hi Debu,
> give it a try. When the line is idle, the line is kept at mark level..
> The start of a data byte is signaled by a start bit at space level.
> The start bit is followed by the defined number of data bits from LSB
> to MSB, the parity bit if defined, and the defined number of stop
> bits, again at mark level. Mark level, according to the document I
> that "MARK condition is normally established by a NEGATIVE voltage on
> the interface." I'm guessing this voltage is probably what you're
> seeing.
> Gregory Ross
I was wondering before if there was anyway in C that I could make the
pin 3 of the serial port to be 0V instead of 5V (after the Max 232
conversion). The 5V is messing things up for me... my one solution
was to put it through a not gate, and then have another not gate at
the other receiving end...
hai,
I am going to assembl my on BS2(board of education).I need help
for interfacing BS2(using serial port) with PC.i am not understanding
the cicuit(board of education manual)confution came from one
photo(basicstamps/group).
anand
I just go a laptop PC that I'd like to use for my Stamp work. but it has no
serial port. Is there a way to add a serial port? It has USB ports and I
think I've seen something about going from USB to serial.
thanks
bob
Apparently, the best USB to serial converter is the
Keyspan 19W -- you can look on their website, and
comp-usa sometimes has them.
Stay away from BELKIN, as they don't support the
'ATN' line (DTR) properly.
it has no
ports and I
> thanks
> bob
You can add a serial port via a PCMCIA card too. I had problems
finding one at first, but I was able to get one at Fry's Electronics.
But as you already may know with Fry's, its hit or miss!
Ed
it has no
ports and I
> thanks
> bob
Beware the sticker-of-death at Fry's -- those return stickers mean its
probably broken or missing parts.
> it has no
> ports and I
--- In basicstamps@yahoogroups.com, "amulet_ed" <edsandoval@h...>
Electronics.
> Ed
but
> it has no
> ports and I
> > thanks
> > bob
--- wndtnnl2000 <wndtnnl2000@y...> wrote:
> just got bs2 and found out need 9 pin serial to
> comm. over. my laptop
> only has vga,parallel printer & usb plus the pdmcia
> port. any help?
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
Yahoo! Finance Tax Center - File online. File on time. http://taxes.yahoo.com/filing.html
What does the DTR pin of the serial port on a PC do? I'm hoping it "clocks"
the communications between a PC and some other device?
David Fixemer
fixemerd@a...
402-472-8239
Has anyone ever hooked up an ADC to the serial port of a computer? How do
you clock the ADC?
David Fixemer
Fixemerd@a...
402-472-8239
Debu
Gregory Ross
Sent: Thursday, November 22, 2001 5:29 AM
Subject: [noparse][[/noparse]basicstamps] Serial Port
> Hi again..
> Thanks
> Debu
the
idle state.
> Hi Debu,
> seeing.
> Gregory Ross
Debu
anand
thanks
bob
it has no
ports and I
> thanks
> bob
Ed
it has no
ports and I
> thanks
> bob
> it has no
> ports and I
Here are a link to the B&B site, they have all sorts of usb> 232,
eithernet> 232, pcmcia> 232 ect. Not cheap but they work well.
http://www.bb-elec.com/add_a_port/serial_usb_chart.asp
Not paid by B&B, I just use their stuff.
Brent
Electronics.
> Ed
but
> it has no
> ports and I
> > thanks
> > bob
only has vga,parallel printer & usb plus the pdmcia port. any help?
wndtnnl2000@y... writes:
> just got bs2 and found out need 9 pin serial to comm. over. my laptop
You will have to get a USB to serial adapter.
Sid Weaver
W4EKQ
Port Richey, FL
http://www.parallax.com/html_pages/products/componentshop/cables_power.asp
> port. any help?
> ignored.
> Yahoo! Groups Links
Do you Yahoo!?
OR here:
http://ebmhost10.ebm.bestsoftwarehost.com/iwwida.pvx?;item?item_no=220-506%20%20\
%20%20%20%20%20%201?comp=cct?%22%3E
http://castle.pricewatch.com/search/search.idq?qc="USB"*+AND+"CONVERTER"*&cr=USB\
+converter
Tom Fisher
BigD
-- Jon Williams
-- Parallax
From: wndtnnl2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=efFN5PxTpmDSrDBE8HKSvpKR4Mgra5rUfd7Ak-uFftzN5TMeadbKv-H6paL1mJwM3f9EB289ag-Yx4U]wndtnnl2000@y...[/url
Sent: Saturday, March 27, 2004 6:01 AM
Subject: [noparse][[/noparse]basicstamps] serial port
