5VDC Reed Relay — Parallax Forums
5VDC Reed Relay
edited 2001-04-17 21:40 in General Discussion
An easy question from a beginner:
I just purchased a 5VDC Reed Relay from radio shack (275-232).
I just want to know the best way to wire this to the stamp without
damaging it. I am assuming I need to wire the stamp to the coil
connections and the other wires go to the circuit I want to switch on
and off. Is this correct? How should I do it safely?
I just want to use the stamp to control a second independent circuit.
Thank You
    edited 2001-04-14 03:48
    You need to drive the relay with a transistor. A 2N2222 works OK.
    Connect one coil terminal to +5 VDC. Connect the other coil terminal to the
    collector of the 2n2222. Connect the emitter of the 2N2222 to ground.
    Connect the base of the 2N2222 to one leg of a 10k resistor and connect the
    other leg of the resistor to the stamp pin.
    edited 2001-04-14 04:10
    One more thing. Put a diode like a 1N914 or 1N4148 (not overly critical)
    "backwards" across the coil. Put the banded end towards +5V and the
    non-banded end to the collector side. This will absorb reverse spikes in the
    coil before they can kill the transistor.
    The voltage developed is almost entirely a function of the speed of the
    switching, so you can get some large (short duration) voltages (this is the
    same idea behind a spark gap, ignition coil, etc.).
    Al Williams
    AWC
    * New PAK-IX floating point A/D: http://www.al-williams.com/awce/pak9.htm
    > From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Cz4ILQNQejBOazEfgpqwX16pbGQfqFsPdwZIuLT3BGuvDtQ52Dzxl9DBFN4csVz04EiztmUOaZLg-A]daweasel@s...[/url
    > Sent: Friday, April 13, 2001 9:49 PM
    > Subject: Re: [noparse][[/noparse]basicstamps] 5VDC Reed Relay
    > terminal to the
    > connect the
    edited 2001-04-14 04:51
    Mike-here is a page with a nice diagram for hooking up a relay to a
    microcontroller. The diode is important to protect the microcontroller from a
    current surge when you turn the relay off and the magnetic field in the coil
    collapses.
    http://www.seattlerobotics.org/encoder/aug99/ballbot.html
    have fun-build robots
    Larry Geib
    ljgeib@a...
    edited 2001-04-16 16:13
    If the relay coil does not have a snubber across it the transistor
    will die a quick, violent death. When the transistor turns off the
    magnetic field in the relay coil collapses. This would appear as a
    (possibly) large voltage spike across the transistor.
    Easiest thing to do:
    place a 1N4007 diode across the relay coil, anode towards the 2n2222
    collector.
    Ciao
    Richard
    terminal to the
    ground.
    connect the
    232).
    switch on
    circuit.
    edited 2001-04-16 16:30
    Depends on the size of the relay. I've run the little ones both with and
    without. As a rule, I use them, but it was the wee hours when I wrote the
    reply and it slipped my mind.
    > collector.
    > Ciao
    > Richard
    > terminal to the
    > ground.
    > connect the
    > 232).
    > switch on
    > circuit.
    edited 2001-04-16 18:47
    I recently bought a package of 20 diodes from Ratshack and I don't recall if
    they have a part number. Question: What kind of problems can occur if I use
    such a generic diode?
    Dave
    > collector.
    > Ciao
    > Richard
    > terminal to the
    > ground.
    > connect the
    > 232).
    > switch on
    > circuit.
    __________________________________________________
    Do You Yahoo!?
    Get email at your own domain with Yahoo! Mail.
    http://personal.mail.yahoo.com/
    edited 2001-04-16 19:01
    david cousins wrote:
    I recently bought a package of 20 diodes from Ratshackand I don't recall if
    they have a part number.· Question: What kind of problems canoccur if I use
    Dave
    --- iceninevt@yahoo.com wrote:
    Generic stamp failure??· LOL!
    Seriously though if the output is not properly protected by the diodeyou can seriously fry your stamp.
    Rus
    Rus Hardy
    "Lucky Devil"
    Atrophies - Ghoulishly Original Awards & Trophies
    http://www.bluedestiny.com/Atrophies/
    SpiderBucky & SpiderThrifty - Boney Superheroes
    http://www.bluedestiny.com/SpiderBucky/
    Keeper of the Bucky-n-Thrifty Flame
    http://www.boneyardbargains.com/
    "my mind wanders....I'm just along for the ride"
    edited 2001-04-16 19:05
    Are you saying that I shouldn't use these generic diodes? That I need a
    special diode for the reed relay protection? I don't think I phrased my
    previous question correctly.
    dave
    > if
    > use
    > > Dave
    > Generic stamp failure?? LOL!
    > Seriously though if the output is not properly protected by the diode you can
    > Rus
    > Rus Hardy
    > "Lucky Devil"
    Do You Yahoo!?
    edited 2001-04-16 19:16
    The voltage spike created by the coils collapsing magnetic field can
    be many times the voltage applied to it. The 1N4007 is a good choice,
    I expect there will be a bunch of them in the RS diode bundle. The RS
    diodes do have part numbers
    Keep in mind that a speaker (not a piezo, a bona-fide voice coil type)
    can damage a stamp, or a transistor, with equal ease as the relay
    coil, for exactly the same reasons.
    Placing a reverse-biased diode across an inductive load should be
    considered an absololute necessity, every single time. There are
    other ways of getting the job done, ie: a RC snubber, but I almost
    always use the diode.
    If you really want to protect your stamp consider coupling the stamp
    output pin to the outside world using an optocoupler. They are not
    difficult to use and afford the largest degree of protection to the
    stamp.
    Regards
    Rich
    recall if
    if I use
    > Dave
    transistor
    the
    a
    2n2222
    > > collector.
    > > Ciao
    > > Richard
    OK.
    > > terminal to the
    > > ground.
    > > connect the
    > > 232).
    without
    coil
    > > switch on
    > > circuit.
    > Do You Yahoo!?
    edited 2001-04-16 19:18
    I bought the same pack of diodes I think, small 2mm glass encapsulated
    kind? I've used them with 5vdc relays in 2 different projects, one is
    nearing 2 years run time without a problem. I've always put the black band
    toward the +5v (if I remember correctly)
    Robert Staph, W3RCS
    The Center for Advanced Technologies
    Sent: Monday, April 16, 2001 2:05 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: 5VDC Reed Relay
    > dave
    recall
    > > if
    I
    > > use
    > > > Dave
    you can
    > > Rus
    > > Rus Hardy
    > > "Lucky Devil"
    > Do You Yahoo!?
    edited 2001-04-16 19:23
    David,
    I am assuming since you are referring to them a "generic" diodes, and they do
    not
    have parts numbers on them and that you have no idea what "type" diodes they
    are.....Is this correct?....
    I would be afraid of using a "generic" diode (one for which you have no
    information) in this case. Especially considering the cost of a stamp versus
    the
    cost of diodes.
    I would spend the few cents and make sure I have a properly rated diode. I'm
    using
    (at the lists recommendation) the 1N4XXX series diodes and have had no problems.
    ie... 1N4001, 1N4005, 1N4007.
    Rus
    > dave
    > > if
    > > use
    > > > Dave
    can
    > > Rus
    Rus Hardy
    "Lucky Devil"
    edited 2001-04-16 19:38
    It's me again, with another version of the diode question:
    With a resistor, we can measure resistance to voltage. Verification by
    measuring voltage drop.
    With a capacitor, we can store a large or small charge. Verification by
    measuring voltage and a time delay.
    Now how about these diodes. Keep in mind that I'm a civil engineer. What
    differentiates one diode from another? Is it a measure of power?
    Thanks in advance.
    dave
    > stamp.
    > Regards
    > Rich
    > recall if
    > if I use
    > > Dave
    > transistor
    > the
    > a
    > 2n2222
    > > > collector.
    > > > Ciao
    > > > Richard
    > OK.
    > > > terminal to the
    > > > ground.
    > > > connect the
    > > > 232).
    > without
    > coil
    > > > switch on
    > > > circuit.
    > > Do You Yahoo!?
    Do You Yahoo!?
    edited 2001-04-16 19:43
    Robert,
    Thanks for the reply. I really enjoy this electronics stuff, and folks like
    yourself, have helped me a bunch.
    Dave
    > Robert Staph, W3RCS
    > From: david cousins <cuz_hsv@y...>
    > > dave
    > recall
    > > > if
    > I
    > > > use
    > > > > Dave
    > you can
    > > > Rus
    > > > Rus Hardy
    > > > "Lucky Devil"
    > > Do You Yahoo!?
    Do You Yahoo!?
    edited 2001-04-16 19:49
    OK then, specifically, let's say I was using a Radio Shack 900-2389 (5V,
    500mA) which maps to a OEG brand model OMR-2-06-F relay. I can't tell
    (although it certainly can be staring me in the face) from the relay
    data sheet what the maximum reverse voltage produced from the coil could
    be. http://www.oeg.com.cn/pdf/14_OMR.pdf
    How would I go about calculating it to make sure my diode can handle it?
    Kevin
    > dave
    > > if
    > > use
    > > > Dave
    can
    > > Rus
    > > Rus Hardy
    > > "Lucky Devil"
    > Do You Yahoo!?
    edited 2001-04-16 20:23
    Voltage drop across a diode is unlike that of a resistor or
    capacitor. The voltage drop across a diode (or most any) P/N junction
    is 600mV (6/10 volt). Usually, this drop is constant, the drop does
    not vary with changes in voltage.
    There are many different types of diodes. They all do basically the
    same thing, allow current flow in only one direction.
    Some diodes are used for rectification, turning AC into DC. Others
    are used for signal detection, etc.
    The ratings that should concern you are:
    PIV Peak Inverse Voltage. A diode will block current in one
    direction, to a point. If to much voltage is appled to a diode, in
    its non-conducting direction (reverse biased) the semiconductor
    junction inside the diode "breaks down". The diode dies, (it usually
    takes something with it.)
    Zener diodes break down without dying, at a specific voltage. Zeners
    are used to protect against overvoltage, and are often used to
    produce a voltage reference.
    Wattage How much power a diode can safely pass
    Some diodes are required to conduct very quickly. Switching power
    supplies use diodes that conduct very quickly to protect the output
    devices. Stepper motor drivers are usually protected by these fast
    diodes.
    More information than you need? You bet!
    Hope some of this helps.
    Good Luck
    Rich
    http://geocities.com/rbc1956
    Verification by
    Verification by
    engineer. What
    > Thanks in advance.
    > dave
    can
    choice,
    The RS
    type)
    almost
    stamp
    not
    the
    > > stamp.
    > > Regards
    > > Rich
    don't
    > > recall if
    occur
    > > if I use
    > > > Dave
    > > transistor
    off
    > > the
    as
    > > a
    > > 2n2222
    > > > > collector.
    > > > > Ciao
    > > > > Richard
    works
    > > OK.
    > > > > terminal to the
    to
    > > > > ground.
    and
    > > > > connect the
    (275-
    > > > > 232).
    stamp
    > > without
    the
    > > coil
    to
    > > > > switch on
    independent
    > > > > circuit.
    > > > Do You Yahoo!?
    > Do You Yahoo!?
    edited 2001-04-16 20:27
    Hi Dave,
    Well there are several important diode parameters. First, the forward
    voltage drop. If the material is silicon (1N914, 1N4148, 1N4XXX...) the drop
    will be about .7V. Some meters can measure this directly with a "diode"
    position. Otherwise, put a battery, a resistor, and a diode in series and
    measure it with a voltmeter. Germanium drops about .3V. Hot carrier and
    Schottky diodes have different forward voltages too.
    The next big thing is the reverse breakdown voltage. If you put a big
    voltage backwards, the diode may emit its internal smoke :-) This is often
    rated as PIV "Peak Inverse Voltage". Diodes with very precise reverse
    breakdowns are used as zener diodes.
    The forward current capacity is another important parameter.
    In some diodes, the junction capacitance is controlled and used as a voltage
    variable capacitor. As the depletion region grows and shrinks the
    capacitance changes.
    There are many special-purpose diodes made to switch, rectify, regulate,
    etc. So the critical parameters change depending on what kind of diode you
    want and why you want it.
    The snub as discussed in the list is pretty non-critical because the reverse
    voltage has very little duration or current. Almost any diode will safely
    short it to ground.
    However, in some cases, diode selection is critical. For example, if you
    were building a crystal-type radio, you'd want to use a Germanium diode so
    you could hear weaker signals. If you were using diodes to switch an
    antenna, you'd want fast switching diodes with controlled capacitance.
    One size doesn't fit all :-)
    BTW, if the Radio Shack bag 'o diodes are clear glass passivated (a clear
    see through case) they are probably Germanium (1N34A? diodes). Not great for
    logic use. Would probably work for the snub, but not my first choice.
    If they are small glass with a reddish body, they are probably 1N914 or
    1N4148 which would be OK. These are about the size of an 1/8W resistor. The
    1N34's are about half between 1/4 and 1/2W size. The '914/'4148 is the
    classic "logic" diode. Fast switching.
    If they are black they are probably 1N4XXX but these are usually marked, at
    least with the last digits (4001 for example). These are OK too. Usually
    used in power supplies.
    This is all from memory. Someone will correct me if I'm wrong.
    Al Williams
    AWC
    *Floating point A/D: http://www.al-williams.com/awce/pak9.htm
    > From: david cousins [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=S46Lku8lTS363Z2JE72Awvoojtt0JP1EfI4PWnZpXoCGvKwZdDLR92CyjPRXqHHPdD9tILFg6A]cuz_hsv@y...[/url
    > Sent: Monday, April 16, 2001 1:39 PM
    > Thanks in advance.
    > dave
    > > stamp.
    > > Regards
    > > Rich
    > > recall if
    > > if I use
    > > > Dave
    > > transistor
    > > the
    > > a
    > > 2n2222
    > > > > collector.
    > > > > Ciao
    > > > > Richard
    > > OK.
    > > > > terminal to the
    > > > > ground.
    > > > > connect the
    > > > > 232).
    > > without
    > > coil
    > > > > switch on
    > > > > circuit.
    > > > Do You Yahoo!?
    Do You Yahoo!?
    edited 2001-04-16 21:11
    Do the diodes have any markings? If so, you can look up the specs. The only
    problem I foresee is getting a zener diode rather than a normal one. If the
    zener is rated below 5 volts, it might conduct when you power the circuit
    up.
    if
    use
    edited 2001-04-16 21:17
    *Usually* the glass ones are 1N914's -- a low-current general-purpose diode.
    Should work fine for a *small* relay like a reed relay or one of the DIP
    relays. Yes, the banded end goes toward +5 VDC.
    band
    edited 2001-04-16 21:21
    Standard diodes are rated by the amount of current they will pass and the
    amount of voltage they will block in the reverse direction. The 1N4007
    referred to previously is rated for one amp with a peak inverse voltage of
    1000 volts.
    If you want the specs, go to:
    http://www.fairchildsemi.com/ds/1N/1N4007.pdf
    edited 2001-04-16 23:11
    Dave:
    The diode only "works" when the relay is turned off, and then usually only
    for a few hundred millisecs. What ratings does the diode need? When the
    relay is on, the diode sees the coil voltage as a reverse stress, so a 12
    volt relay would need a diode rated greater than 12 volts PIV, (peak inverse
    voltage). When the relay is turned off, the diode will momentarily carry
    whatever the relay coil current was. If it is a 500 ma coil, the diode
    should be rated for 500 ma, (or more), forward current, (If).
    Summary:
    If >= coil current
    PIV >= coil voltage.
    The high voltages mentioned in this thread only occur without a diode. If
    you use the generic diodes, and they are not rated for the coil current, the
    diode will pop, you lose your protection, then the transistor dies. A
    simple test, if you want to use the cheap diodes, is to connect the diode
    across the power supply, band to positive. If it doesn't pop, it has a high
    enough PIV. Now connect the diode in series with the relay and apply the
    normal relay voltage + 0.7 volts. If the diode doesn't pop, it has an
    adequate If.
    Hope this helps,
    Ray McArthur
    if
    use
    edited 2001-04-17 15:37
    As many of you said, my diodes do have part numbers on them, and I did save the
    tag in the bottom of my parts bin. They are indeed the 1N914's.
    Thanks to everyone for their inputs and teaching. Your responses have
    provided me with numerous little learning tasks to cement these studies.
    I also searched on the optoisolators and started learning about them. Of
    course I immediately have questions. Hoping that I haven't already worn out my
    welcome, I will ask it.
    Does the optoisolator have an internal LED and Phototransisoter inside the
    chip?
    The switching is done with only light? Since no electricity is passed between
    the circuits, they are isolated? If so, very cool.
    Thanks again.
    Dave
    > band
    Do You Yahoo!?
    Yahoo! Auctions - buy the things you want at great prices
    http://auctions.yahoo.com/
    edited 2001-04-17 17:09
    Yup. There is no electrical connection between the input and output on the
    opto-isolator. These are typically used to isolate a low-voltage circuit
    from a high-voltage circuit. We used them to drive 110 VAC relays with
    logic-level signals.
    You'll still probably have to use a transistor to drive the relay -- most
    opto-isolators are very low current.
    save the
    out my
    > chip?
    between
    edited 2001-04-17 17:32
    Yep
    The switching is done only with light. Inside the optoisolator
    (photocoupler) is a LED and either a photodiode or phototransistor.
    Opto's come in a ton of flavors...
    Some are used as triac drivers. What this means is that your stamp
    could switch an AC load (like your coffee maker or lights) with just
    a small handful of parts, and without using a relay. Sometimes the
    relay is a good choice, but is is a mechanical device, it is slow,
    noisy, and being a mechanical device has a much shorter life than a
    solid state switch (like a triac)
    Opto's do many, many other things.
    if these things interest you I would recommend you get a trial copy
    of Nuts and Volts magazine (www.nutsvolts.com) and consider
    subscribing.
    I am a new "stamper", I got my BS2 three weeks ago. I have found NV
    to be very stamp-friendly. A good source for electronics info, and
    for stamp hints. I am 44 years old and my electronics education
    stopped about 20 years ago, until three weeks ago, when I got my BS2.
    It is never to late to learn. Good Luck
    Regards
    Rich
    did save the
    have
    studies.
    them. Of
    worn out my
    inside the
    > chip?
    passed between
    > Thanks again.
    > Dave
    purpose diode.
    the DIP
    encapsulated
    one is
    the black
    > > band
    That I need a
    phrased my
    > Do You Yahoo!?
    edited 2001-04-17 21:11
    Personally I like optos, I've used them alot in robot applications.
    They really do protect a lot of sensitive electronics from high current
    lines going to a motor. They also cut out any knid of noise that
    motors will generate. Plus optical anything gives it a very high tech
    ambience.
    -Ryan
    I'm hearing alot about opto-isolators. Can anyone recommend a few part
    numbers that work well with stamps? I'm looking for smaller footprint
    types, I've seen them in an 6 or 8 pin dip before. I'd be interested in
    ones that could do 12vdc at around 1A, and ones that do 120vac at 1A.
    Also simplicity of design is good too. If I don't need a farm of external
    components, I'd love to start using them. Just never had any good leads on
    ones that would match up well with stamps.
    Robert Staph, W3RCS
    Computer Networking Consultant (CNC-DPT)
    Sent: Tuesday, April 17, 2001 4:11 PM
    Subject: [noparse][[/noparse]basicstamps] Re: 5VDC Reed Relay
    > ambience.
    > -Ryan
