BS2 and PAK8 help needed.
Hello all, especially Al
Could someone give me some advice please.
Im using:
A BS2 powered by a 9volt battery.
A PAK8 powered by a regulator and a couple of capacitors from the same
battery.
2 servos powered by 4 1.5v cells.
I have an led on pin0 to show that the code is looping.
All the earths are tied.
When I download my code (included below) to the stamp from the development
environment. Everything works.
If I turn off the power to the stamp and PAK8 then turn on again. The servos
will either turn randomly or not at all.
If I then reset the stamp by earthing the reset pin. everything works as I
expect.
Is there an issue with what order the stamp and the PAK device are powered
up ?
or am I missing something obvious ?
Any tips would be appreciated.
Heres my code. Its a slightly modified version of the example supplied with
the PAK8 <<<<
' Change these to suit your setup
datap con 15 ' Data pin (I/O)
datapin var in15
clk con 14 ' Clk pin (output)
led con 0 ' led pin
' Register names
DURLOW con %000
DURHIGH con %001
HIGHDUR con %010
LOWDUR con %011
PSCALE con %100
PSBASE con %101
N con %110
CTRL con %111
center0 con 150
center1 con 150
output clk
output datap
output led
fpx var word ' Integer used by
some routines
fpb var byte ' byte
' parameters for FCommand
chan var nib
register var nib
' my routine here
gosub freset ' always reset!
gosub FTotalReset ' hard reset
' disable channel 0 + 1
chan=0
register=6
fpx=1
gosub FCommand
chan=1
gosub FCommand
gosub ServoCenter
for chan=0 to 1
fpb=3
gosub FJam
next
pause 5000
gosub forwards
pause 5000
gosub backwards
here:
toggle led
pause 250
goto here
end
' Subroutines
' Center servos
ServoCenter:
chan=0
register=1
fpx=center0 ' 150 x 10 = 1.5mS
gosub FCommand
chan=1
fpx=center1
gosub FCommand
register=2
fpx=2000 ' 2000 x 10 = 20mS
gosub FCommand
chan=0
goto FCommand ' let FCommand return
forwards:
chan=0
register=1
fpx=center0 + 10
gosub FCommand
chan=1
fpx=center0 - 10
gosub FCommand
return
backwards:
chan=0
register=1
fpx=center0 - 10
gosub FCommand
chan=1
fpx=center0 + 10
gosub FCommand
return
' Reset the Pak8 I/O
FReset:
LOW DATAP
LOW CLK
HIGH CLK
HIGH DATAP
LOW CLK
return
' 0 is 0, 1 is 1, 2 is hi-z, 3 is
normal
' note: 3 enables channel to run!
FJam:
fpb=chan + (fpb<<3)+%01000000
goto FSendByte
FCommand:
' inputs chan = channel, register
= register
fpb=(register<<3) + chan
gosub FSendByte
fpb=fpx.lowbyte
gosub FSendByte
fpb=fpx.highbyte
goto FSendByte
FReadReg:
fpb=(register<<3) + chan +
%10000000
gosub FSendByte
' fall into FReadWord
FReadWord:
Shiftin
datap,clk,MSBPRE,[noparse][[/noparse]fpx.lowbyte,fpx.h
ighbyte]
return
FTotalReset:
fpb=$FF
FSendByte:
Shiftout datap,clk,MSBFIRST,[noparse][[/noparse]fpb]
return
FReadByte:
shiftin datap,clk,MSBPRE,[noparse][[/noparse]fpb]
return
FPrescale:
' set fpb to the prescale constant
fpb = fpb + $C0
goto FSendByte
Im using:
battery.
expect.
up ?
the PAK8 <<<<
datapin var in15
led con 0 ' led pin
' Register names
DURLOW con %000
DURHIGH con %001
HIGHDUR con %010
LOWDUR con %011
PSCALE con %100
PSBASE con %101
N con %110
CTRL con %111
center0 con 150
center1 con 150
output clk
output datap
output led
some routines
fpb var byte ' byte
chan var nib
register var nib
' my routine here
chan=0
register=6
fpx=1
gosub FCommand
chan=1
gosub FCommand
gosub ServoCenter
for chan=0 to 1
fpb=3
gosub FJam
next
pause 5000
gosub forwards
pause 5000
gosub backwards
here:
toggle led
pause 250
goto here
end
' Subroutines
' Center servos
ServoCenter:
chan=0
register=1
gosub FCommand
chan=1
fpx=center1
gosub FCommand
register=2
gosub FCommand
chan=0
forwards:
chan=0
register=1
fpx=center0 + 10
gosub FCommand
chan=1
fpx=center0 - 10
gosub FCommand
return
backwards:
chan=0
register=1
fpx=center0 - 10
gosub FCommand
chan=1
fpx=center0 + 10
gosub FCommand
return
FReset:
LOW DATAP
LOW CLK
HIGH CLK
HIGH DATAP
LOW CLK
return
normal
FJam:
goto FSendByte
FCommand:
= register
gosub FSendByte
fpb=fpx.lowbyte
gosub FSendByte
fpb=fpx.highbyte
goto FSendByte
FReadReg:
%10000000
gosub FSendByte
FReadWord:
Shiftin
ighbyte]
return
FTotalReset:
fpb=$FF
FSendByte:
return
FReadByte:
return
FPrescale:
fpb = fpb + $C0
goto FSendByte
It sounds like you have a reset problem. The PAK-VIII needs a fairly fast
rise on Vdd or it will brown out. Here are some things to think about:
1) Noise. Use decoupling caps. Also, make sure no inputs are floating.
2) Slow Vdd. Vdd must rise and stabilize within about 15mS or so. You can
determine if this is the problem by connecting the reset pin to Vdd through
a 10K resistor. If the chip doesn't work, leave the power on and briefly
ground the reset pin by touching a clip lead to the "cold" end of the
resistor. If the chip works, you have a reset problem. You can try
connecting the reset pin to the Stamp's reset pin or using an RC reset
circuit.
3) Clock problems. A 50MHz clock requires low stray capacitance and short
leads. In some cases, a 10K resistor across the resonator will help. In some
cases, a small capacitor from one (or both) of the RES pins will help. It
depends on your construction. Ideally, you shouldn't need either of those,
but it can help neutralize circuit oddities you may have.
The fact that it works OK after you reset means your code should be OK. The
brute force fix would be to tie the Stamp's reset pin to the reset pin of
the PAK. However, if Vdd rises quickly enough that shouldn't be a problem.
Let me know if that helps!
Al Williams
AWC
* NEW: PAK-IX floating point A/D: http://www.al-williams.com/awce/pak9.htm
> From: Endersby, Gordon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EShATIfJo_g3d9ijXL1Pb7rvdM8nB_Rj2QAfEqXEM3Eh-06yeUnUwtOqVYpNhg4wnUanPwA3VQikCZzio74DtLg]gordon.endersby@m...[/url
> Sent: Wednesday, April 11, 2001 5:53 AM
> Subject: [noparse][[/noparse]basicstamps] BS2 and PAK8 help needed.
> Im using:
> battery.
> The servos
> expect.
> up ?
> supplied with
> the PAK8 <<<<
> datapin var in15
> led con 0 ' led pin
> ' Register names
> DURLOW con %000
> DURHIGH con %001
> HIGHDUR con %010
> LOWDUR con %011
> PSCALE con %100
> PSBASE con %101
> N con %110
> CTRL con %111
> center0 con 150
> center1 con 150
> output clk
> output datap
> output led
> some routines
> fpb var byte ' byte
> chan var nib
> register var nib
> ' my routine here
> chan=0
> register=6
> fpx=1
> gosub FCommand
> chan=1
> gosub FCommand
> gosub ServoCenter
> for chan=0 to 1
> fpb=3
> gosub FJam
> next
> pause 5000
> gosub forwards
> pause 5000
> gosub backwards
> here:
> toggle led
> pause 250
> goto here
> end
> ' Subroutines
> ' Center servos
> ServoCenter:
> chan=0
> register=1
> gosub FCommand
> chan=1
> fpx=center1
> gosub FCommand
> register=2
> gosub FCommand
> chan=0
> forwards:
> chan=0
> register=1
> fpx=center0 + 10
> gosub FCommand
> chan=1
> fpx=center0 - 10
> gosub FCommand
> return
> backwards:
> chan=0
> register=1
> fpx=center0 - 10
> gosub FCommand
> chan=1
> fpx=center0 + 10
> gosub FCommand
> return
> FReset:
> LOW DATAP
> LOW CLK
> HIGH CLK
> HIGH DATAP
> LOW CLK
> return
> normal
> FJam:
> goto FSendByte
> FCommand:
> = register
> gosub FSendByte
> fpb=fpx.lowbyte
> gosub FSendByte
> fpb=fpx.highbyte
> goto FSendByte
> FReadReg:
> %10000000
> gosub FSendByte
> FReadWord:
> Shiftin
> ighbyte]
> return
> FTotalReset:
> fpb=$FF
> FSendByte:
> return
> FReadByte:
> return
> FPrescale:
> fpb = fpb + $C0
> goto FSendByte
Im new to electronics so I need to ask a couple of extra questions about
your reply.
Im learning fast though, Apart from reliably reading resistor values.
1, How do I work out the values for the capacitors and where do I put them ?
Do they go from the +5v from the regulator to the earth before I connect the
PAK to the +5v.
I thought that having a seperate regulator, even though its sharing an
earth,
would isolate the electronics from the noise from the servos.
2, I can follow this one.
3, Ive got this on a prototyping board and the resonator is about 1cm from
the PAK8.
Is that too far? The prototyping board is one of those where you can press
in the component leads.
I beleive its called a euroboard.
10k resistor across the resonator. Do you mean join the two outer pins of
the resonator with a resistor ?
Where do I connect the capacitor/s? From the outer pins to where ?
Thanks again
Gordon
From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Y_qH0ABAsIPguFjUfzVUAxmhcfrY3NNTfTBll2RjEWMyjM92XhLa6mn2Mfi7UacziW9WUunSt8JDpvrkkD0]alw@a...[/url
Sent: 11 April 2001 14:32
Subject: RE: [noparse][[/noparse]basicstamps] BS2 and PAK8 help needed.
Hi Gordon,
circuit.
Al Williams
AWC
> From: Endersby, Gordon [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WBzNeorK_4wFPybVUVSM6kCUvsSGKM4N8D2P3XS86PS_sQ_MEgdAgpVHh2xpgytKSgQ0YxjZCAJjF_6DcYHeCsbWig]gordon.endersby@m...[/url
> Im using:
> battery.
> The servos
> expect.
> up ?
> supplied with
> the PAK8 <<<<
> datapin var in15
> led con 0 ' led pin
> ' Register names
> DURLOW con %000
> DURHIGH con %001
> HIGHDUR con %010
> LOWDUR con %011
> PSCALE con %100
> PSBASE con %101
> N con %110
> CTRL con %111
> center0 con 150
> center1 con 150
> output clk
> output datap
> output led
> some routines
> fpb var byte ' byte
> chan var nib
> register var nib
> ' my routine here
> chan=0
> register=6
> fpx=1
> gosub FCommand
> chan=1
> gosub FCommand
> gosub ServoCenter
> for chan=0 to 1
> fpb=3
> gosub FJam
> next
> pause 5000
> gosub forwards
> pause 5000
> gosub backwards
> here:
> toggle led
> pause 250
> goto here
> end
> ' Subroutines
> ' Center servos
> ServoCenter:
> chan=0
> register=1
> gosub FCommand
> chan=1
> fpx=center1
> gosub FCommand
> register=2
> gosub FCommand
> chan=0
> forwards:
> chan=0
> register=1
> fpx=center0 + 10
> gosub FCommand
> chan=1
> fpx=center0 - 10
> gosub FCommand
> return
> backwards:
> chan=0
> register=1
> fpx=center0 - 10
> gosub FCommand
> chan=1
> fpx=center0 + 10
> gosub FCommand
> return
> FReset:
> LOW DATAP
> LOW CLK
> HIGH CLK
> HIGH DATAP
> LOW CLK
> return
> normal
> FJam:
> goto FSendByte
> FCommand:
> = register
> gosub FSendByte
> fpb=fpx.lowbyte
> gosub FSendByte
> fpb=fpx.highbyte
> goto FSendByte
> FReadReg:
> %10000000
> gosub FSendByte
> FReadWord:
> Shiftin
> ighbyte]
> return
> FTotalReset:
> fpb=$FF
> FSendByte:
> return
> FReadByte:
> return
> FPrescale:
> fpb = fpb + $C0
> goto FSendByte
> put them ?
> connect the
> PAK to the +5v.
> I thought that having a separate regulator, even though its sharing an
> earth,
Decoupling capacitors should be very close to the chip they are protecting.
In general, you want at least one per chip. A .1UF will decouple high
frequency noise. A 1uF cap will decouple a lot of noise also. In some
applications you'll use both. The prototyping boards will tend to impress
the clock noise on every pin because the board has a lot of capacitance and
at 50MHz, that clock will wind up throughout the board. So the regulator
isn't really an issue.
Think about it this way. If you were building on a "perfect" circuit board
(which doesn't exist) each part would be isolated from every other. However
with a protoboard, you are basically attaching a capacitor from each wire to
every adjacent wire. At DC that doesn't matter. But as frequency rises those
capacitors look more like resistors (1/(2*pi*F*C)). So you basically have
little resistive shorts between your circuit elements.
> the PAK8.
No that shouldn't be too far. Make sure the leads are not any longer than
necessary. I have found some protoboards (the less expensive ones) won't
work well at all no matter what even at 10 or 20MHz. But I regularly layout
50MHz oscillators for PAKs on protoboards.
Yes, that is one thing you can try if the clock is not starting.
The capacitors should be small in value (10-20pF) and would go from the
clock pins to ground.
Neither of these steps should be necessary and if you have a scope and can
see that the clock is reliably starting then you don't need them at all.
However, sometimes the protoboard's stray capacitance and other factors can
keep the clock from starting and these steps _might_ help.
Al Williams
AWC
Wife and kids allowing ill give it a try tonite.
Gordon
From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Fq5ANg0uQGU6DOxlo_ieHMO35R2c9ZpIaRqEPzinolg2zE-lRs8HTtv7oQv2xz9vZ7vRCijQozbv130]alw@a...[/url
Sent: 11 April 2001 15:06
Hi Gordon,
> put them ?
> connect the
> PAK to the +5v.
> earth,
> the PAK8.
Al Williams
AWC
