BS1 Rev D Reset? — Parallax Forums
BS1 Rev D Reset?
edited 2001-04-11 23:27 in General Discussion
Anyone know why the BS1 Rev D has no reset? Can one be added?
I'm trying to integrate one into a retired RC car for line following and I
need a way to restart the code until I can fit something else.
    edited 2001-04-11 17:48
    The rev D has the reset pin on the PIC chip tied directly to the +5
    volt power supply, so you can't get at it without hacking. You can
    reset it though simply by turning the power off and on. That is no
    big deal because the chip only draws 2 ma when running. The power
    supply must turn on fast and clean to get a good reset with the PIC
    chip's built-in reset circuit. The more recent BS1-IC has a standard
    external reset chip, the purpose of which let it respond to slowly
    rising power supplies and to brownouts.
    -- Tracy
    edited 2001-04-11 18:30
    Gracias.
    I was trying to cobble together a line follower out of an RC car and I
    didn't want to waste too many parts or too much time until I start making
    the final version. I've got the board and battery tied down to a piece of
    plastic and wanted a way to restart it without disconnecting the battery.
    The eventual game plan is to have a photocell or something you wave your
    hand over to start the car.
    The Rev D is already bought, so the other processor is not an option right
    now. I guess the description of the two processors being electrically
    equivalent is not totally correct?
    I
    edited 2001-04-11 18:55
    This makes me wonder how equivalent the stampII module and the PLC
    interpretor/build your own stamp are as well. I never could get servos to
    work off the build your own style of stamps, but easily drive servos off the
    BS2IC. Considering the hundreds of Typo errors in Parallax's documentation I
    am not surprised.
    At 12:30 PM 4/11/2001 -0500, you wrote:
    >Gracias.
    >I
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    Sincerely
    Kerry
    Admin@M...
    WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
    Kerry Barlow
    p.o. box 21
    kirkwood ny
    13795
    de nada.
    Well, you could hack the rev D. Pin 4 on the PIC dip chip is the
    reset. I don't have a rev D board in front of me to check the
    traces, but let's say you could cut the trace that leads to that pin.
    Or just take the chip out of its socket, and bent pin 4 out so it
    doesn't go back into the socket. Connect a 5k pullup resistor from
    the pin to +5 volts. And connect a wire from the pin to the top side
    of a pushbutton or sensor, the other side to ground, and there is
    your reset. The rise and fall times on the reset input do not have
    to be real fast, because the PIC has a built in threshold detector on
    that pin. However, noise on that pin would show up as erratic
    behavior in the car!
    --good luck!
    Tracy Allen
    http://www.emesystems.com
    >Rodent wrote:
    >Gracias.
    >I
