Newbie, VB to BS2
On 7 Apr 01 at 3:55, furryspinto@y... wrote:
> main:
> kts var byte
> serin 16,16468,[noparse][[/noparse]kts]
> if kts <79 then ORANGEono
> if kts >80 then GREENono
> if kts >120 then REDono
Third IF is never executed since second IF already caught these...
Try this instead:
IF kts > 120 THEN REDono
IF kts < 79 THEN ORANGEono
GREENono:
Or, the Tracy Allen "We don't need no stinking spaghetti code"
solution:
BRANCH kts/40,[noparse][[/noparse] ORANGEono, ORANGEono, GREENono, REDono... ]
Steve
> main:
> kts var byte
Try this instead:
GREENono:
solution:
Steve
I've searched through as much of the group and found a couple of
things that I might try. Here's my prob.
I have written a small terminal program in VB6, eventually it will be
used as the GUI for the user. I am using it currently to test SERIN,
SEROUT, (experimenting).
I would like to control the state of 3 LED's depending on the input
from the user. The bs2 code is is below. The circuit works, and
communication is established with PC/BS2.
If the user enters a number between 0 & 79 no problem orange LED goes
on.
Now the peoblem starts, the green LED does not go on unless the
number enterd is greater than 100, and the Red LED will never go on
regardless. I can switch back and forth between the Orange and Green
LED but not with the numbers I prescribed. My original thinking was
that maybe BS2 saw the number as Binary, but 100 is not Binary for 80.
Am I way off track here? Anyhelp getting me pointed in the right
direction is appreciated, don't worry about offending me if my BS2
code is real sloppy, I'm just new to it ;-)
Thanks in advance.
output 0 'sets pin 5 P0 as output
output 1 'sets pin 6 P1 as output
output 2 'sets pin 7 P2 as output
goto LEDoff
main:
kts var byte
LEDoff:
out0=1
out1=1
out2=1
goto main
GREENono:
out0=0
out1=1
out2=1
goto main
REDono:
out0=1
out1=0
out2=1
goto main
ORANGEono:
out0=1
out1=1
out2=0
goto main
Jeff explained it. The kts/40 just takes advantage of the multiples
of 40 inherent in your specified cutoff points, plus how the integer
divide works, to yield a branch index. With some thought, you can
often use techniques like this to write "cleaner" code and minimize
code space requirements.
Steve
On 8 Apr 01 at 7:36, Chris Anderson wrote:
> Hello Steve or Tracy, can you give a quick explanation of the
> "kts/40" below, does it simply make branch segments of 40, such as
> ,0 to 40, 41 to 80, 81 to 120, >120,
high 0 'sets pin 5 P0 as output, led off
high 1 'sets pin 6 P1 as output, "
high 2 'sets pin 7 P2 as output, "
main:
kts var byte
serin 16,16468,[noparse][[/noparse]kts] ' this is the BS2 baud rate 9600
outL=~kts ' makes the low 3 bits follow the ascii codes
' ~ inverts all bits
goto main
Then when you type characters "A", "B", "C" etc. the leds should
light up in a binary sequence.
>from the user.
>snip...
>goto LEDoff
>main:
>kts var byte
>LEDoff:
> out0=1
> out1=1
> out2=1
>goto main
>GREENono:
> out0=0
> out1=1
> out2=1
>goto main
>REDono:
> out0=1
> out1=0
> out2=1
>goto main
>ORANGEono:
> out0=1
> out1=1
> out2=0
>goto main
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
below, does it simply make branch segments of 40, such as ,0 to 40, 41 to
regards, Chris
" BRANCH kts/40,[noparse][[/noparse] ORANGEono, ORANGEono, GREENono, REDono... ]"
The objects within the brackets are separated by commas and are addressed
as 0,1,2,3, etc. The "Branch kts/40" divides kts by forty. So if kts = 80
then it will be divided by forty =2 =GREENono. If kts=39 then a division by
40 will = less than one which the stamp interprets as zero (ORANGEono)
Hope this helps
Jeff
operator or anything fancy.
Chris
Sent: Sunday, April 08, 2001 7:52 AM
Subject: Re: [noparse][[/noparse]basicstamps] Newbie, VB to BS2
> Chris,
addressed
by
> Hope this helps
> Jeff
Thanks to everyone that took the time to look at my question, I
really learned a great deal from all of your suggestions!
Andy
