Stamp 2 servo, stepper, and keypad help
Well first, I have a 3x4 keypad in which i could buy the encoder chip
for a 4x4 but if possible would like to bypass it and directly pulse
a servo motor, the length of the pulse and direction depending on
which key is pressed. Then I would like to stimulate a stepper motor
and position it at its final resting spot. At the same time, i would
like to turn on a 110v motor and another servo. At this point, is
this possible?? My inclination is that with the 2e, I do not have
enough pins. I think that I need help programming, and that I need
to connect a few BASIC Stamp 1's together. If what I stated above is
possible, our final goal is that once a photodiode is crossed, the
final servo and DC motor will stop until the photodiode is cleared,
and then turned on again for a finite amount of time.
Any advice or words of wisdom is greatly appreciated.
Thank you,
Sarah Hembree
Thank you,
Sarah Hembree
