BS2 program
Can someone give me the simple program to send a variable(number)from
a BS2 through the TWS-434 to the RWS-434 and then have it read by
hyperterminal on a computeR? This would be a great help. Furthermore,
is there anyone who can tell me what connections should be made to the
DB9 port? Any specific pins should be grounded?
I am using a DS275 to convert voltage levels.
Corey.
Corey.
another stamp for the RWS I can tell you how to do it. I am communicating
from Stamp to hyperterminal without the TWS/RWS combo.
Sid
I am under a tight dead-line......hmmm....I have another stamp, but I
think it is fried...(not sure though)
--- In basicstamps@y..., Newzed@a... wrote:
> What you are trying to do can be done but it is pretty tough. If
you have
communicating
> Sid
All you need is two good pins on your "fried" stamp - one pin to serin the
data from the RWS and one to serout the same data to hyperterminal.
Sid
