Optimization
Ok guys, this is my first stamp project and I was wondering if there would
be any way to optimize this code. It takes in data from sensors and sends
out midi. I'd appreciate any help.
sensorA var word
sensorB var word
sensorC var word
sensorD var word
sensorE var word
sensorF var word
sensorG var word
sensorH var word
channel var byte
x var byte
MAINLOOP:
Sample:
high 9
pause 1
RCTIME 9,1,x
if x = 0 then channel1
if x = 32 then channel2
if x = 64 then channel3
if x = 128 then channel4
Sensor1:
high 1
pause 1
RCTIME 1,1,sensorA
debug ? sensorA
if sensorA > 100 then midiout1
Sensor2:
high 2
pause 1
RCTIME 2,1,sensorB
if sensorB > 100 then midiout2
Sensor3:
high 3
pause 1
RCTIME 3,1,sensorC
if sensorC > 100 then midiout3
Sensor4:
high 4
pause 1
RCTIME 4,1,sensorD
if sensorD > 100 then midiout4
Sensor5:
high 5
pause 1
RCTIME 5,1,sensorE
if sensorE > 100 then midiout5
Sensor6:
high 6
pause 1
RCTIME 6,1,sensorF
if sensorF > 100 then midiout6
Sensor7:
high 7
pause 1
RCTIME 7,1,sensorG
if sensorG > 100 then midiout7
Sensor8:
high 8
pause 1
RCTIME 8,1,sensorH
if sensorH > 100 then midiout8
goto MAINLOOP
channel1:
channel = 0
goto Sensor1
channel2:
channel = 1
goto Sensor1
channel3:
channel = 2
goto Sensor1
channel4:
channel = 3
goto Sensor1
midiout1:
serout 15,$8000+12,0,[noparse][[/noparse]144+channel,60,(sensorA*127)/5000]
goto Sensor2
midiout2:
serout 15,$8000+12,0,[noparse][[/noparse]144+channel,62,(sensorB*127)/5000]
goto Sensor3
midiout3:
serout 15,$8000+12,0,[noparse][[/noparse]144+channel,63,(sensorC*127)/5000]
goto Sensor4
midiout4:
serout 15,$8000+12,0,[noparse][[/noparse]144+channel,65,(sensorD*127)/5000]
goto Sensor5
midiout5:
serout 15,$8000+12,0,[noparse][[/noparse]144+channel,67,(sensorE*127)/5000]
goto Sensor6
midiout6:
serout 15,$8000+12,0,[noparse][[/noparse]144+channel,68,(sensorF*127)/5000]
goto Sensor7
midiout7:
serout 15,$8000+12,0,[noparse][[/noparse]144+channel,70,(sensorG*127)/5000]
goto Sensor8
midiout8:
serout 15,$8000+12,0,[noparse][[/noparse]144+channel,72,(sensorH*127)/5000]
goto MAINLOOP
sensorA var word
sensorB var word
sensorC var word
sensorD var word
sensorE var word
sensorF var word
sensorG var word
sensorH var word
channel var byte
x var byte
MAINLOOP:
Sample:
high 9
pause 1
RCTIME 9,1,x
Sensor1:
high 1
pause 1
RCTIME 1,1,sensorA
debug ? sensorA
Sensor2:
high 2
pause 1
RCTIME 2,1,sensorB
Sensor3:
high 3
pause 1
RCTIME 3,1,sensorC
Sensor4:
high 4
pause 1
RCTIME 4,1,sensorD
Sensor5:
high 5
pause 1
RCTIME 5,1,sensorE
Sensor6:
high 6
pause 1
RCTIME 6,1,sensorF
Sensor7:
high 7
pause 1
RCTIME 7,1,sensorG
Sensor8:
high 8
pause 1
RCTIME 8,1,sensorH
goto MAINLOOP
channel1:
channel = 0
goto Sensor1
channel2:
channel = 1
goto Sensor1
channel3:
channel = 2
goto Sensor1
channel4:
channel = 3
goto Sensor1
midiout1:
goto Sensor2
midiout2:
goto Sensor3
midiout3:
goto Sensor4
midiout4:
goto Sensor5
midiout5:
goto Sensor6
midiout6:
goto Sensor7
midiout7:
goto Sensor8
midiout8:
goto MAINLOOP
I'll make some suggestions in line with your code...
>sensorA var word
>sensorB var word
>sensorC var word
>sensorD var word
>sensorE var word
>sensorF var word
>sensorG var word
>sensorH var word
>channel var byte
>x var byte
>MAINLOOP:
>Sample:
>high 9
>pause 1
>RCTIME 9,1,x
I am guessing you want inequalities there, because RCtime is very
unlikely to return exactly 32, 64 or 128, or 0 (1 is the minimum, 0
only occurs if there is a overrun).
These gotos just substitute a value [noparse][[/noparse]channel=0,1,2,3] and come back
to the label sensor1 just below. Instead, you might be able to use
simply
channel=ncd (x/32)
This returns
channel:=0 for 0=x<=31
channel:=1 for 32=x<=63
channel:=2 for 64=<=127
channel:=3 for 128=x<=255
Is a byte variable for x always going to work? If RCtime gets up to
x=256, it is going to rollover back to zero.
>Sensor1:
>high 1
>pause 1
>RCTIME 1,1,sensorA
>debug ? sensorA
>Sensor2:
>high 2
>pause 1
>RCTIME 2,1,sensorB
...snip etc. for 8 sensors.
This is fine, but if you want to be tricky you could combine them all
into one for-next loop. There do not have to be separate variables
for each sensor.
SensorX var word
i var nib
Sensors:
for i=1 to 8
high i
pause 1
RCtime i,1,sensorX
if sensorX<=100 then nextsensor ' skip sending data
serout 15,$8000+12,0,[noparse][[/noparse]144+channel,60,(sensorX*127)/5000]
nextSensor:
next
>goto MAINLOOP
the following were your channel assignments, maybe not needed, see above
>channel1:
>channel = 0
>goto Sensor1
>channel2:
>channel = 1
>goto Sensor1
>channel3:
>channel = 2
>goto Sensor1
>channel4:
>channel = 3
>goto Sensor1
The following were the serouts, maybe can be part of a short for-next
loop, see above.
>midiout1:
>goto Sensor2
>midiout2:
>goto Sensor3
>... snip..and so on for 8 sensors.
I hope that is instructive. I'd say you did really well for a first
Stamp project!!
-- regards,
Tracy Allen
http://www.emesystems.com
in this thread is fascinating and might be one of the most useful learning
tools for me. I appreciate the time and effort that a lot of you pro's
dedicate to answering our questions, I know it must get mundane at times.
Three cheers for our altruistic friends.
Jeff
