DIP switches, serial devices — Parallax Forums
edited 2001-04-03 22:47 in General Discussion
Bob-
Perhaps you considered and rejected this already, but you don't need
48 switches to perform a 1-of-40 selection. With 6 switches, you
have 64 possible settings. That may or may not bring the number of
switches down low enough to hang them directly off of Stamp pins, but
it ought to lower the shift register or whatever count.
Steve
On 3 Apr 01 at 13:56, Bob Pence wrote:
> Is there an IC analogous to an Analog to Digiatal Converter that can
> be used to read DIP switches via a serial connection, synch or
> asynch? I am looking to use 4 banks of 12 DIP switches so that the
> end user will have some control over process variables (e.g. do
> something for 5, 10, 15, 20, 30, or 40 seconds)...
    edited 2001-04-03 14:56
    something for 5, 10, 15, 20, 30, or 40 seconds). Dedicating an I/O
    pin to each DIP switch is out of the question. I've thought about
    using an ADC and ignoring the least significant couple of bits, but
    this seems to be the wrong path.
    Regards
    Bob Pence
    edited 2001-04-03 15:06
    Hi Bob,
    This is a perfect place to use the "one pin, many switches" app note in the
    Stamp manual. The idea is to make a switch-controlled potentiometer and then
    use RCTime to read the current resistance (along with a known capacitor).
    You'd have to make sure that each combo results in a unique resistance you
    could differentiate, but I'm sure you could come up with something
    (especially if you dedicate a pin per bank).
    For example, consider 3 dip switches. Put a 220 resistor and a .1uF cap.
    Then put 3 resistors in series (1K, 2K, 4K) so that when the switch is
    closed, the corresponding resistor is shorted out (0 ohms). Now:
    000 - 7220
    001 - 3220
    010 - 5220
    011 - 1220
    100 - 6220
    101 - 2220
    110 - 4220
    111 - 220
    An RCTime could easily differentiate between these.
    You could also use a shift register (actually, more than one).
    Al Williams
    AWC
    * NEW: PAK-IX adds floating point math and A/D! Coming soon:
    http://www.al-williams.com/awce
    > From: Bob Pence [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WMcBsEO3zwoU8pAeD7_9hBPE3pZV9i0JhekeS2O4MdeuL5RyyvcCj8ypvsmRqZrOqAxq4nqx8Zixkx_7dEbhyRJ5]bobpence_2000@y...[/url
    > Sent: Tuesday, April 03, 2001 8:56 AM
    > Subject: [noparse][[/noparse]basicstamps] DIP switches, serial devices
    > Regards
    > Bob Pence
    edited 2001-04-03 15:22
    You could use a resistor network, where each switch increased or decreased
    the resistance. Then use RCTIME to get the resistance. There was a good
    example of this in the Robot Builders Bonanza.
    edited 2001-04-03 18:03
    >Regards
    >Bob Pence
    Hi Bob,
    This is a good application for a shift register:
    http://www.fairchildsemi.com/pf/MM/MM74HC165.html
    You would need 5 of them to handle the 48 switches, and 5 resistor
    networks for pullups, and maybe capacitors for de-bouncing. The 5
    shift registers can be chained together, so that you only need 3
    stamp pins for the interface, and 3 SHIFTIN commands.
    Another approach would be an 8x8 matrix, with a 74hc164 or a 74hc595
    for the output rows, and a 74hc165 for the input columns, scanning in
    software.
    I would not recommend the RCtime solution for that many switches.
    The CPU processing needed for de-bouncing the switches is pretty
    demanding. You have to assure you have captured a good value, as
    opposed to a reading in transition.
    -- regards,
    Tracy Allen
    http://www.emesystems.com
    edited 2001-04-03 18:09
    Hi Tracy,
    This is a good point, but if the DIP switches are like most DIP switches,
    they are set once before power up and then never changed again. In that
    case, I don't think the RC solution is that bad. You are right though -- if
    the switches change on the fly, that might not be a good idea.
    Al Williams
    AWC
    *NEW: PAK-IX Floating point A/D converter...
    http://www.al-williams.com/awce/pak9.htm
    you can ues parallel in serial out shift registers.
    cascade them to each other for more positions than 1 alone.
    norm
    >From: Tracy Allen <tracy@e...>
    >Reply-To: basicstamps@yahoogroups.com
    >Subject: Re: [noparse][[/noparse]basicstamps] DIP switches, serial devices
    >Date: Tue, 03 Apr 2001 10:03:05 -0700
    > >Regards
    > >Bob Pence
    >Hi Bob,
    >software.
    > -- regards,
    > Tracy Allen
    _________________________________________________________________
    Get your FREE download of MSN Explorer at http://explorer.msn.com
