Error encore
Hi everyone,
What does it mean if this error message comes up when trying to
download to the stamp...keep in mind I tried many different batteries
and used fresh 9 volts:
BASIC Stamp II found but is not responding.
Check power supply
Followed sometimes by:
Cannot open port.
Reason unknown.
Corey.
Check power supply
Cannot open port.
Reason unknown.
Corey.
>Hi everyone,
>Check power supply
>Cannot open port.
>Reason unknown.
>Thanks,
>Corey.
It's been a long time since I have used a stamp, but I seem to remember
an error similar to that when I would attempt to program a stamp, while
the previous stamp code used serout extensively (16 only not 0-15).
Unfortunately, the solution in this case seemed to be pressing ALT-R
repetitively until the program would take.
Note: This could be a side effect from the ATN modification using two
.1uF capacitors as an automatic switch.
...Try taking the ATN pin on the stamp (#3 I think?) directly to
+5V if the above may be the case.
Beau Schwabe IC Mask Designer
National Semiconductor Network Products Division
500 Pinnacle Court, Suite 525 Mail Stop GA1 Norcross, GA 30071
