LEDs and for...next
Archiver
I'm a beginner (15 years old) with the Basic Stamp2 and I was wondering how
to get a LED, connected to pin 0, to light up when I push a button,
connected to pin 1.
I was also wondering how to get 10 LEDs, connected to pins 0 through 9, to
light up in sequence, but with four lit up at any one time. So LED numbers
0, 1, 2, and 3 are lit up in the start, then LED 3 goes off, 4 on, 4 off, 5
on, 5 off, and so on until all of the possible combinations of four have
been reached. How would I be able to do that without programming each
individual LED when to turn on and off?
Thanks.
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com
connected to pin 1.
Thanks.
wondering how to get a LED, connected to pin 0, to light up when I
push a button, connected to pin 1.
through 9, to light up in sequence, but with four lit up at any one
time. So LED numbers 0, 1, 2, and 3 are lit up in the start, then LED
3 goes off, 4 on, 4 off, 5 on, 5 off, and so on until all of the
possible combinations of four have been reached. How would I be able
to do that without programming each individual LED when to turn on
and off?
Thanks.
'put a 4700 ohm resistor from pin1 to +5volts
'put the switch from pin1 to ground (0 volts)
'put the led and a 470 ohm resistor IN SERIES from pin 0 to ground
start:
if pin1 = 1 then ledoff
pin0 = 1
goto start
ledoff:
pin0=0
goto start
'hope this is some help
'Chris
> and off?
'You could try this, putting a 470 ohm resistor and led between each i/o pin
(from 0 to 9) and ground.
counter var byte
start:
For counter = 0 to 9
high counter
pause 1000
low counter
goto start
Sent: Sunday, April 01, 2001 10:05 AM
Subject: [noparse][[/noparse]basicstamps] LEDs and for...next
> and off?
> Thanks.
sjohns10@hotmail.com writes:
MyButton ····VAR ····In1
MyLED ·······VAR ····Out0
Initialize:
·Dir0 = 1 ················' make pin 0 an output
Main:
·MyLED = MyButton
·GOTO Main
This program assumes that you have a normally-open pushbutton between pin 1
and +5. ·You must also connect a 10K resistor between pin 1 and ground. ·The
resistor will hold the pin at 0 when the button is open.
Connect the LED to pin 0. ·You need to limit the current with a resistor so
the connection is something like this: Pin0 -- LED -- resistor -- ground.
The resitor value can be anything from 220 ohms to 1K.
and off?
Download my book, StampWorks, from the Parallax website (you can by from
Parallax or from Amazon.com). ·The book will teach you Stamp 2 programming
through 31 different experiments. ·One of the experiments is a lighting
sequencer which will show you how to accomplish your second goal.
-- Jon Williams
-- Dallas, TX
[/font]
How about:
OUTPUT 0
top:
out0=in1
goto top
Of course, if the LED is backwards with respect to the switch you could try:
OUTPUT 0
top:
out0=in1^1 ' xor 1 will flip the in1 bit
goto top
As for the other, how about:
mask var word
dirs=%1111111111111111
resetmask:
mask = %0000000000001111
again:
outs=mask
pause 500
mask=mask<<1
if mask=%0000111100000000 then resetmask ' (or whatever)
goto again
Once you have that, try making them reverse direction :-)
Al Williams
AWC
* Microcontroller Projects with Basic Stamps:
http://www.al-williams.com/awce/sbook.htm
> From: Seth Johnson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ePtmHcsaC7AWFGYxwE7Os0NNSvkH9svFsas1SAI7wyDr6RScyPSS94GuFfrUr9gzYSeZv0ebLhRxTAco5w]sjohns10@h...[/url
> Sent: Saturday, March 31, 2001 8:02 PM
> wondering how
> connected to pin 1.
> through 9, to
> LED numbers
> on, 4 off, 5
> Thanks.
