Pocket Watch B
>I would like to know if the Pocket Watch B has the ability to run a
longer
>timing sequence than available from the Long Astable Alarm. I need
to turn
>on a recyclable output for more than the 256 minutes. (8hrs. on, 16
off,
>then repeat) I thought about using the Short Astable Alarm set up as
an
>hourly timer and have the Basic Stamp 2 count the transitions. What
is the
>best way to go about this? If the cycle were to come on at 9:00pm
and go off
>at 5:00pm, 7 days per week, what would the code look like? I realize
you
>can't take the time to write specific code, but if you will steer me
to some
>similar examples or the proper direction it will be a big help.
Thank you.
>RC
longer
to turn
off,
an
is the
and go off
you
to some
Thank you.
>RC
reading the datasheet, and it shows one connected 1-wire to a BS1,
but has anyone used it on a BS2 (There's probably a N&V Column for
this question)?
One other question...What's a good/recommended battery-backup for
this device for the time?
Chris
>Has anyone used the Pocket Watch B in your BS2 projects? I was
>this question)?
>Chris
Chris -
Take a looks here at the Solutions Cubed web site for applications notes for
using the Pocket Watch B on each of the various Stamps:
http://www.solutionscubed.com/Solutions%20Cubed/PWB2003.htm
Bruce Bates
> Chris -
> for applications notes for using the Pocket Watch B
Thanks Bruce, I did find some code and one more
datasheet, however, nothing on Battery Backup methods.
I interested in one of these modules for a home-made
Smart-Thermostat...Instead of buying one I think I'll
build one. But all the clock chips I see that are
easy to connect to the BS2 have no battery backup.
Parallel BBRTC chips from Dallas have built-In lithium
batteries, but if I can come up with a simple enough
serial RTC I will use it.
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________
Do you Yahoo!?
Yahoo! Mail SpamGuard - Read only the mail you want.
http://antispam.yahoo.com/tools
Battery backup--I think the following would work:
schottky
SD103
Vdd --->]
o
PWB Vcc
| SD103
_____
--- 4.5 to 5 volts
Vss
The PWB draws 3.5 milliamps, and there is no super-low power mode as
far as I know, so the backup battery will have to be hefty enough to
sustain that drain. It could be 4 niCad cells trickle charged from
the 5 volt supply, or 3 alkaline cells. I think the PWB is a PIC
chip that is programmed as a real time clock with all those neat
features.
Other serial real time clock chips like the NJU6533 or the DS1302
take a bit more Stamp programming. But the standby current is ~1
microamp down to as low as 1.5 volts, so they can be backed up by a
lithium battery or capacitor.
-- Tracy
>--- Bruce Bates <bvbates@u...> wrote:
>> Chris -
>Chris Savage
>Knight Designs
>(607) 535-6777
chip has provision for battery backup.
Add a 3-volt coin cell to the right pins,
and you're good to go. Battery drain
current is very low also (microamps?)
I havn't run one until the battery died,
so I can't give you life figures...
--- In basicstamps@yahoogroups.com, Chris Savage
> > Chris -
> Chris Savage
> Knight Designs
> (607) 535-6777
> Do you Yahoo!?
so it requires a little more code (for non-BS2p Stamps).
-- Jon Williams
-- Dallas Office
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GgYYdQp95AVtWqyuggWWfFa6mpeRIGh_nXprHQGXUnwFQ058tu-p64Eo13tth970n443PIADDhV0ZLpDnIiUYHt0n5M]allan.lane@h...[/url
Sent: Sunday, February 22, 2004 1:56 PM
Subject: [noparse][[/noparse]basicstamps] Re: Pocket Watch B
I believe the Dallas 1302 (or is it 1306)
> > Chris -
> Smart-Thermostat...Instead of buying one I think I'll build one. But
> all the clock chips I see that are easy to connect to the BS2 have no
> battery backup. Parallel BBRTC chips from Dallas have built-In lithium
> Chris Savage
> Knight Designs
> (607) 535-6777
> Do you Yahoo!?
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
> Hi Chris,
> schottky
> SD103
> Vdd --->]
o
PWB Vcc
> | SD103
> _____
> --- 4.5 to 5 volts
> Vss
Checking all possibilities for this (Allan and Jon
also made replies), but if I was to use this, my one
question is, would a Ni-Cad pack trickle charge in
this circuit configuration? I am not familiar with
those diodes having used mostly 1N4XXX series...
Knight Designs
(607) 535-6777
Do you Yahoo!?
Well, I wouldn't need one to run off battery very
long...In fact, in the summer the circuit won't even
be used. It's only for when the main power goes out
here. I will look up the PDF Datasheets on those
chips (I think I have a 1302) and the one Jon
mentioned.
Knight Designs
(607) 535-6777
Do you Yahoo!?
Okay, it looks as though the DS1302 WILL work for me,
if I can find a battery or supercap to run off the
trickle-charge circuit. Thing is, it looks like I
will need to calculate a charge based on a formula
provided, but I have to look and see where the
resistor goes. Thanks for the lead, I do have 2
DS1302 chips as well as the crystals.
Knight Designs
(607) 535-6777
Do you Yahoo!?
Okay, on my previous message, I hadn't read far enough
into the DS1302 datasheet...I now see it appears to
have the diodes and resistors needed for the charging
circuit internally, they just need to be selected
according to the charging current required. Which
means, if I use a SuperCap or Ni-Cad pack, I need to
know the charge rate.
Knight Designs
(607) 535-6777
Do you Yahoo!?
a typical coin cell would be good for 5 years.
Just a thought, and it would get you away from
the charging/overcharging/etc. issues.
Having said that, if you only need power backup,
a 'super-cap' will probably give you a few weeks --
but you can't buy a super-cap at the local Walmart,
where they do have 2032 coin cells.
> Chris Savage
> Knight Designs
> (607) 535-6777
> Do you Yahoo!?
> If the battery backup is hardly ever used,
Well, if the 2032 coin cell will work with the DS1302,
I will use it. I stock CR2032 (Duracell) at the shop
for computer backup batteries.
Knight Designs
(607) 535-6777
Do you Yahoo!?
Are you looking for absolute minimum power consumption, where every
microamp counts? If so, read the electrical specifications of the
DS1302 carefully about standby current in relation to Vcc1 and Vcc2.
-- used with a lithium coin cell, be sure the trickle charge is
disabled (trickle charge register=0)
-- be sure to use the 6 pf crystal specified, and don't allow any
stray capacitance from your circuit board. These things are touchy
about that.
Looking at the pocket watch B, I don't know, there might be some
undocumented option for a micro power standby mode.
-- Tracy
>Chris Savage
>Knight Designs
>(607) 535-6777
> Chris,
> to Vcc1 and Vcc2.
Tracy, no, this isn't any kind of critical power
situation. It's merely a programmable thermostat
using the BS2, and an LCD, but I needed an RTC so I
could program the schedule, and I wanted minimal
compensation for power loss, which happens about once
every 6 to 8 weeks. So, nothing critical...I can
always verify the RTC when I get home and have to
reset all the other clocks that are screwed up
whenever the power goes out.
> trickle charge is
> don't allow any
> things are touchy
> about that.
Thanks for the advice...I'm not sure on the crystals,
but now that you have mentioned it, I will check
tomorrow at the shop.
Knight Designs
(607) 535-6777
Do you Yahoo!?
