Free Oscilloscope Questions
One of our members posted a link for a free computer based Oscilloscope.
http://polly.phys.msu.su/~zeld/oscill.html The documentation does not
contain instructions on attaching probes. Is it safe to attach a couple of
probes to my sound card and start plugging away? Should I install resistors
between probe and line in? Thanks in advance.
Jeff
Jeff
I connect the inputs to the "line" input of my soundblaster PCI card, because
the "mike" input is not stereo.
If you never connect to a device that uses more than 6V, no resistor or
protection are needed.
Don't forget to select the line input and a suitable volume in the "recording"
setup of your card.
Regards
ECO
Sent: jeudi 29 mars 2001 06:36
Subject: [noparse][[/noparse]basicstamps] Free Oscilloscope Questions
> Jeff
have laying around. Guess it depends on which you value more in case of
accidents, the sound card or receiver.
I'm interested in how this (or like) software performs, any opinions?
Kevin
ECO wrote:
> Jeff
setup of your card.
> Regards
> ECO
> From: "Jeff Mitchell" <EL-JEFE@P...>
> > Jeff
Another thing you could do is use a pot.
Connect your probe between right- & left pin, conect the left pin to GND and
connect the Line-In between left- & center pin. Then if you allways start
with the wiper at the position nearest the GND-pin and slowly turn it up you
would be safe.
Good luck.
/Henrik Olsson.
Oscilloscope.
resistors
> Jeff
Bandit
At 12:18 PM 3/29/01 +0200, you wrote:
>Jeff
because the "mike" input is not stereo.
"recording" setup of your card.
>Regards
>ECO
resistors
>> Jeff
I posted the Scope link as many people were requesting such
The software came from a sound card preamp kit
The probes plug into the pre amp which as four position gain switch
(10,1,0.1,0.001) which gives greater range than using the probes direct with
the soundcard with the added bonus of isolation (to a degree)
The preamp used a stereo in line giving the user two channel (Sound=L,R,Comm
Scope=A,B,Comm)
The kit can be obtained by mail order (should that be email order?) from
either Dick Smith Electronics or Jaycar Electronics in Australia at
www.dse.com.au and www.jaycar.com.au I think
I have used mine for about twelve months now and couldn't be happier
Any problems just send me an email
Cheers
Wayne
Sent: Thursday, March 29, 2001 2:36 PM
Oscilloscope.
resistors
> Jeff
What is the bandwidth of this Kit Scope. It is not
listed in the advertisement from the web-site.
Also, does the software allow you to do any storage or
triggering?
Adam
--- wayne <vegman@i...> wrote:
> Jeff,
> requesting such
> a degree)
> Scope=A,B,Comm)
> in Australia at
> couldn't be happier
> Cheers
> Wayne
> computer based
> Oscilloscope.
> Should I install
> resistors
> > Jeff
__________________________________________________
Do You Yahoo!?
Get email at your own domain with Yahoo! Mail.
http://personal.mail.yahoo.com/?.refer=text
The sampling being limited by the sound card to 44Khz, the theoretical bandwith
is 22Khz.
In fact, to be able to see more or less the form of the wave or pulse, you are
limited to 10Khz.
Triggering and storage are implemented.
Take care that, depending of your sound card, the signal may be displayed
inverted.
This is not a problem for sound waves but well for pulses if you don't know.
Regards
ECO
Sent: vendredi 30 mars 2001 18:39
Subject: Re: [noparse][[/noparse]basicstamps] Free Oscilloscope Questions
> Wayne,
> triggering?
> Thanks,
> Adam
> > Jeff,
> > I ????? posted the Scope link as many people were
> > requesting such
