Alarm System Project Help
My problem is that i have 6.15 volts going in to an I/O pin when the sensor
pin ejects while being detached from an item. The Stamp sees the change
sometimes and other times it doesnt. but when sensor1 is detached, then the
data for sensor 4 is display, and when sensor 8 is detached the info for
sensor 6 is displayed. I cant figure out what it is....was maybe thinking
that the 6.15 volts needs to be dropped to 5 volts. I am using the COUNT
command to read the port. is this code correct? Or shoudl I use a different
method to smaple the voltage on the line?
I get a completely different result when I test only the first sensor alone.
Everything seems to be ok. Im frustrated with this thing. :-}
Thanks.
So, here is my code...
LETTER VAR BYTE
SENS1 VAR BYTE
SENS2 VAR BYTE
SENS3 VAR BYTE
SENS4 VAR BYTE
SENS5 VAR BYTE
SENS6 VAR BYTE
SENS7 VAR BYTE
SENS8 VAR BYTE
IN CON 0
OUT CON 1
GREEN CON 8
RED CON 9
ALRM CON 10
DIR0=IN
DIR1=IN
DIR2=IN
DIR3=IN
DIR4=IN
DIR5=IN
DIR6=IN
DIR7=IN
DIR8=OUT
DIR9=OUT
DIR10=OUT
DIR11=OUT
DIR12=OUT
DIR13=OUT
DIR14=OUT
DIR15=OUT
TOP:
SEROUT 16, 84, 10, [noparse][[/noparse]"OK"]
GOSUB RECEIVE
IF (LETTER="G") THEN TEST1
GOTO ERROR
TEST1:
LOW ALRM
LOW RED
HIGH GREEN
COUNT 1, 5, SENS1
IF (SENS1=0) THEN TEST2
SEROUT 16, 84, 10, [noparse][[/noparse]"11111110"]
GOTO ALARM
TEST2:
COUNT 2, 5, SENS2
IF (SENS2=0) THEN TEST3
SEROUT 16, 84, 10, [noparse][[/noparse]"11111101"]
GOTO ALARM
TEST3:
COUNT 3, 5, SENS3
IF (SENS3=0) THEN TEST4
SEROUT 16, 84, 10, [noparse][[/noparse]"11111011"]
GOTO ALARM
TEST4:
COUNT 4, 5, SENS4
IF (SENS4=0) THEN TEST5
SEROUT 16, 84, 10, [noparse][[/noparse]"11110111"]
GOTO ALARM
TEST5:
COUNT 5, 5, SENS5
IF (SENS5=0) THEN TEST6
SEROUT 16, 84, 10, [noparse][[/noparse]"11101111"]
GOTO ALARM
TEST6:
COUNT 6, 5, SENS6
IF (SENS6=0) THEN TEST7
SEROUT 16, 84, 10, [noparse][[/noparse]"11011111"]
GOTO ALARM
TEST7:
COUNT 7, 5, SENS7
IF (SENS7=0) THEN TEST8
SEROUT 16, 84, 10, [noparse][[/noparse]"10111111"]
GOTO ALARM
TEST8:
COUNT 8, 5, SENS8
IF (SENS8=0) THEN TEST1
SEROUT 16, 84, 10, [noparse][[/noparse]"01111111"]
GOTO ALARM
RECEIVE:
SERIN 16, 84, 60000, RECEIVE, [noparse][[/noparse]LETTER]
RETURN
ALARM:
HIGH ALRM
LOW GREEN
HIGH RED
GOSUB RECEIVE
IF (LETTER="S") THEN STP
GOTO ERROR
STP:
LOW ALRM
GOTO STP
ERROR:
LOW GREEN
HIGH RED
GOTO TOP
Shop online without a credit card
http://www.rocketcash.com
RocketCash, a NetZero subsidiary
Thanks.
LETTER VAR BYTE
SENS1 VAR BYTE
SENS2 VAR BYTE
SENS3 VAR BYTE
SENS4 VAR BYTE
SENS5 VAR BYTE
SENS6 VAR BYTE
SENS7 VAR BYTE
SENS8 VAR BYTE
IN CON 0
OUT CON 1
GREEN CON 8
RED CON 9
ALRM CON 10
DIR0=IN
DIR1=IN
DIR2=IN
DIR3=IN
DIR4=IN
DIR5=IN
DIR6=IN
DIR7=IN
DIR8=OUT
DIR9=OUT
DIR10=OUT
DIR11=OUT
DIR12=OUT
DIR13=OUT
DIR14=OUT
DIR15=OUT
TOP:
GOSUB RECEIVE
GOTO ERROR
TEST1:
LOW ALRM
LOW RED
HIGH GREEN
COUNT 1, 5, SENS1
GOTO ALARM
TEST2:
COUNT 2, 5, SENS2
GOTO ALARM
TEST3:
COUNT 3, 5, SENS3
GOTO ALARM
TEST4:
COUNT 4, 5, SENS4
GOTO ALARM
TEST5:
COUNT 5, 5, SENS5
GOTO ALARM
TEST6:
COUNT 6, 5, SENS6
GOTO ALARM
TEST7:
COUNT 7, 5, SENS7
GOTO ALARM
TEST8:
COUNT 8, 5, SENS8
GOTO ALARM
RECEIVE:
RETURN
ALARM:
HIGH ALRM
LOW GREEN
HIGH RED
GOSUB RECEIVE
GOTO ERROR
STP:
LOW ALRM
GOTO STP
ERROR:
LOW GREEN
HIGH RED
GOTO TOP
Make the pin an input using the INPUT command and use "if then" logic to
test the state. Check out the stamp manual....
I'm not sure how the external circuitry is hooked up to the stamp, but a
possible pitfall might be that when you expect the state to be '0' it is not
GROUNDED (as it should be) and is actually floating. If its floating, you
may get unexpected results (e.g. from parasitic capacitance on a
breadboard).
--Craig
From: wtterrell [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pzlRvxX05q6cVeM0fb8YziMlAtedKc7u7W1wOmvOai5W4ygiUjrLW7UgA1PS0Y9DIF6SvuXuQSuvaE_GYw]wtterrell@n...[/url
Sent: Wednesday, March 28, 2001 9:30 AM
Subject: [noparse][[/noparse]basicstamps] Alarm System Project Help
Thanks.
LETTER VAR BYTE
SENS1 VAR BYTE
SENS2 VAR BYTE
SENS3 VAR BYTE
SENS4 VAR BYTE
SENS5 VAR BYTE
SENS6 VAR BYTE
SENS7 VAR BYTE
SENS8 VAR BYTE
IN CON 0
OUT CON 1
GREEN CON 8
RED CON 9
ALRM CON 10
DIR0=IN
DIR1=IN
DIR2=IN
DIR3=IN
DIR4=IN
DIR5=IN
DIR6=IN
DIR7=IN
DIR8=OUT
DIR9=OUT
DIR10=OUT
DIR11=OUT
DIR12=OUT
DIR13=OUT
DIR14=OUT
DIR15=OUT
TOP:
GOSUB RECEIVE
GOTO ERROR
TEST1:
LOW ALRM
LOW RED
HIGH GREEN
COUNT 1, 5, SENS1
GOTO ALARM
TEST2:
COUNT 2, 5, SENS2
GOTO ALARM
TEST3:
COUNT 3, 5, SENS3
GOTO ALARM
TEST4:
COUNT 4, 5, SENS4
GOTO ALARM
TEST5:
COUNT 5, 5, SENS5
GOTO ALARM
TEST6:
COUNT 6, 5, SENS6
GOTO ALARM
TEST7:
COUNT 7, 5, SENS7
GOTO ALARM
TEST8:
COUNT 8, 5, SENS8
GOTO ALARM
RECEIVE:
RETURN
ALARM:
HIGH ALRM
LOW GREEN
HIGH RED
GOSUB RECEIVE
GOTO ERROR
STP:
LOW ALRM
GOTO STP
ERROR:
LOW GREEN
HIGH RED
GOTO TOP
