TWS Interface(& DS275)
1. If connecting the RWS-434 to the DS275 for reading the incoming
data with hyperterminal: what are the exact connections between the
DS275 and RWS-434? Do the unused pins(most) have to be grounded? Any
simple schematics around?
2. Is there any specific way the data should be sent from the
transmitting end so that hyperterminal will read the data? Or will it
read it if I just send the variable(just a number)?
3. With this wireless stuff, there is no need to worry about cutting
the ATN line from the transmitting STAMP, correct?
Corey.
--- In basicstamps@y..., sargent@s... wrote:
> I've not been following this thread too closely, but would like to
throw in
> that I also have had great results with the DS275.
> = Steve
> At 10:54 PM 03/27/2001 -0500, you wrote:
> >Rodent wrote:
> >> If you need true PC variety RS232, you have to use a line driver.
For TTL
> >> level you should not.
> >I guess this is where my confusion is, the definition of 'true PC
> >variety RS232'. I've tried on 4 different PC, all where able to
> >directly read from the stamp, no line driver (all at short, < 4' cable
> >lengths). And assuming a short cable run is fine for a given
> >applicaiton so direct stamp->PC sems to work, what about PC->stamp. Do
> >you know of any badness from using the PC->22Kresistor->stamp method?
> >> FYI -- we used Max232's on some equipment where we used to work
and got
> >> 500'+ distance at 300 baud. the new stuff used Max495's and we
were able to
> >> go 1500'+ at 9600 baud.
> >OK, this sounds like a good example of greater cable length needing
> >higher voltages.
> >Thanks,
> >Kevin
> >Your use of Yahoo! Groups is subject to
Corey.
throw in
> = Steve
For TTL
and got
were able to
> >higher voltages.
> >Thanks,
> >Kevin
If you haven't yet, download the datasheet for the DS275 from the following
address
http://www.dalsemi.com/datasheets/pdfindex.html
It has good examples on hook up
Steve
At 12:25 PM 03/28/2001 -0000, you wrote:
>Hi,
>Thanks,
>Corey.
>throw in
>> = Steve
>For TTL
>and got
>were able to
>> >higher voltages.
>> >Thanks,
>> >Kevin
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
