Question: bsII, checking inputs.
hi
this is what i like to do
i like to program a vending machine
if a coin is inserted (controlling a switch) a lamp must burn for 30
minutes
but if the lamp 10 minutes burn , another coin is inserted, the lamp
must burn 30-10=20 + 30 =50 minutes.
it is also possible to insert 2 coins in a row
so what's my problem?
during the "in use" time i find it hard to check the switch.
when i check the switch in a loop with a little pause sometimes i mis
a inserted coin and when i make the loop faster the loop must run
very many times
i like to do this with as less hardware as possible .
thanks a lot
martin van dijk (Holland)
minutes
very many times
thanks a lot
latches the gate... once the stamp reads the state it clears the latch for
the next coin. as long as you are polling fast enough you should be ok. A
quad latch is available (74XXX serries dont remember the part right now) for
about $0.79 and in a DIP14.
MH
Sent: Wednesday, March 28, 2001 3:41 AM
Subject: [noparse][[/noparse]basicstamps] Question: bsII, checking inputs.
> hi
> minutes
> very many times
> thanks a lot
If you wait in a whole bunch of little bits instead of all at once you can do
it without any hardware.
What I do is: enter a loop.
Pause 1 ms.
Check the input(s)
Increment the counter.
If it reaches the time limit (in milliseconds adjusted for the routine)
Exit or return to the loop.
Here is a sample of code from a machine controller program.
Motion_Wait_PAC_500:
if PAC_Motion_In = 0 then Run_500
TMR1 = TMR1 + 1
pause 1
if TMR1 > 30000 then PAC_Misfire
if Plasma_Stop = 0 then PAC_500_Off
goto Motion_Wait_PAC_500
This way you can wait and look for other inputs at the same time.[/font]
