BS2 OEM kit question
Has anyone bought a BS2 OEM kit and put it together themselves recently?
I sent the following question to parallax last week, but haven't heard
back.
The kit comes with a 47k Ohm resistor and there is a diagram on the pcb to
put the resistor between two of the terminals of the crystal. However,
this step is not mentioned in the construction details that came with the
kit and I couldn't find any info on their website (their circuit diagrams
on the website don't contain the resistor).
Does anyone know if I should solder the resistor in place? (The stamp
seems to work without it...)
Nick
back.
Nick
works, assume this is a misprint.
By the way, how did the assembly go? Does it look like its worth the money?
I'm not worried about space, so I thought about using an OEM BS2 for some
stuff on the robot due to the lower cost.
> back.
>back.
You will.
I asked the same question and their answer was that it is not needed with the
current kits. There was an older revision that did.
I believe the resistor should be used, It's a new item because the the
stamp is using a new Interpreter chip which is slightly different
electrically.
You can find additional info under the what's new section at parallax
then download the following pdf
"Notice of Change in BS2 Interpreter Chip Hardware"
It should mention this additional resistor
good luck,
Steve
>back.
>Thanks,
>Nick
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
their way to mention that it does not affect BSII modules or OEM BSII's
because, the resistor is already installed.........................
It should mention, that for the OEM "Kit" it is also necessary. It does
suggest a 10K resistor across the oscillator pins, not a 47K ???????????????
At 05:59 PM 03/27/2001 -0600, you wrote:
>Hi Nick,
>electrically.
>good luck,
>Steve
>>back.
>>Thanks,
>>Nick
I bought the same kit and soldered the 47K in place. The Stamp works fine.
Sean
Sent: Tuesday, March 27, 2001 4:37 PM
Subject: [noparse][[/noparse]basicstamps] BS2 OEM kit question
> back.
> Thanks,
> Nick
about an hour to put all the components in (then it took about half an
hour to figure out the I had to use my COM1 port, not COM2 - I still
haven't figured out why).
I bought the OEM kit to save money and to have the fun of putting it all
together. I also don't have/ haven't made a carrier board for the BS2 IC,
and the OEM provides a DB9 input/ voltage regulator and I didn't feel
like shelling out the extra money without knowing if the stamp would be
useful. It is indeed useful and I have had a lot of fun since I got
it (although I haven't programmed in BASIC since the mid-eighties...).
Now to get my little robot to go speeding around the apartment...
Nick
> > back.
to avoid walls -- pretty interesting. Next I do the servos and IR ranging
modules.
> The assembly was very easy. The pcb is well marked. It took a total of
