Can the debug window ?
Archiver
Hi, I was wondering how to get the debug window to receive floating or
at least decimals with their fractional part to at least tenth point?
example; if 16/12 = 1.33......
bits on a 5V reference. That is about .0195V per count, right? So suppose
instead of computing:
v = count * .0195 (which we can't do), we write:
v = count * 195 (which we can do)
Now the units are actually in .001V so for 4.5V you'd get about 230 counts.
So v = 230 * 195 = 44850 (ok for 16 bits).
You want to .1V, so we can round like this:
v = (v+500)/1000 { that will give us 45)
So how do you display this properly? Easy:
Debug dec v/10, ".", v//10
This works out nicely because it is only one digit. More digits takes more
work. Why? What if you didn't round, but instead wrote:
dec v/10000, ".", v//10000
That would work in this case, giving you 4.4850. But what if the answer were
40500? Then you'd get 4.500 instead of 4.0500. Not insurmountable, but
something you have to watch for.
Another answer is to use a PAK-I or PAK-II to do real 32-bit floating point
math with the Stamp. See http://www.al-williams.com/awce/pak1.htm and
http://www.al-williams.com/awce/doclib.htm
Al Williams
AWC
* Expand your Stamp I/O: http://www.al-williams.com/awce/pak3.htm
> From: SAN CHRISTOPHER POISSON [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Kq5pwI22dsSg_CDGNGIXiXHiNtHjhBE73KWluzsM6SB-Orhn3I-1_GkYjBSHm8M4ZHAWd1W_0z4]sp71@s...[/url
> Sent: Sunday, March 25, 2001 8:40 PM
> Subject: [noparse][[/noparse]basicstamps] Can the debug window ?
Chris
Sent: Monday, March 26, 2001 10:55 AM
Subject: RE: [noparse][[/noparse]basicstamps] Can the debug window ?
> That depends on what you are doing. Suppose you read an A/D count that is
8
counts.
were
point
> Regards,
> Al Williams
> AWC
> > From: SAN CHRISTOPHER POISSON [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_17LzDotaG_dXC6I3Ay4oZhsHROeTpPpJkVShTDPwWtcgFwEW97krYnXeDBEZxNiVMSaENK-oQ]sp71@s...[/url
Or use
debug dec v/10000,".",dec4 v
The decN modifier always picks the N least significant digits.
I have a little writeup on this subject (including negative numbers)
at this URL:
http://www.emesys.com/BS2math4.htm#Displaydecimal
-- Tracy Allen
