counting variable
I am using an optical slotted switch (interrupter) as an encoder to
generate pulses from a slowly rotating disc attached to a wheel.· The
disc has 32 slots cutout along its diameter.· As the slots move thru
the optical slotted switch, pulses are generated. The wheel moves in
one direction for a certain number of slots or it will move in the
opposite direction for a number of slots.· It is designed to never
complete a full rotation.· The rotation is slow because the wheel has
reduction gears on it.· If I want, I could design a disc with twice
as many slots for a more accurate positioning, but 32 slots is good
for right now.· As you can imagine, the pulses generated by this
wheel come very slowly.· My question is this: If I want to stop this
wheel after any given number of pulses in either direction, how would
I construct the program?· I know that I need to use a count variable,
but I am unsure how to use it.· Please show me a sample program using
the count variable. Thank you.
Ken
Ken
Some fuel systems I work with use 3 opto's to detect direction (reverse flow
generates an error). 3 opto's is probably the answer, but the code would
take a bit of work. Perhaps some external logic control before the stamp
might be worth a thought.
Otherwise a microswitch lightly dragged by the wheel in either direction
could be a simple answer. The switch would be on in one direction and off in
the other. If you could do this, the code would require you to first sense a
change in the opto state, then check the direction of the microswitch. Sorry
dont have time to help with code at the moment.
Chris
Sent: Monday, March 26, 2001 7:54 AM
Subject: [noparse][[/noparse]basicstamps] counting variable
generate pulses from a slowly rotating disc attached to a wheel. The
disc has 32 slots cutout along its diameter. As the slots move thru
opposite direction for a number of slots. It is designed to never
complete a full rotation. The rotation is slow because the wheel has
reduction gears on it. If I want, I could design a disc with twice
for right now. As you can imagine, the pulses generated by this
wheel come very slowly. My question is this: If I want to stop this
I construct the program? I know that I need to use a count variable,
but I am unsure how to use it. Please show me a sample program using
Ken
0 or 1 value.
Pulses = 0
Loop:
'MOTOR ON
IF IN0 = 1 THEN Count
GOTO Loop
Count:
Pulses = Pulses + 1
IF Pulses = 32 THEN Exit_Loop
GOTO Loop
Exit_Loop:
'MOTOR OFF
