Cut ATN Line
On 26 Mar 01 at 11:44, the_coin_guy@y... wrote:
> Is there a quick way to cut the ATN line after programming so that
> hyperterminal can be used to read incoming info?
Corey-
Here's a 1997 message to the Stamp list from Beau Schwabe that I
saved. Looks like you want technique #2.
Steve
...The problem is with the ATN line on the StampII or DTR line
from the PC. There are THREE ways that I know of to work
around this problem either through software or hardware.
Manual Hardware Switch Method:
Stamp Side PC-Side (9-Pin connector)
Sout >
> RX(2)
Sin >
> TX(3)
ATN >---o----[noparse][[/noparse]SWITCH]
> DTR(4)
o--/\/\--o
4.7K |
GND >
o
> GND(5)
SWITCH - RUN(open) / PROGRAM(closed)
Automatic Hardware Switch Method: (Thanks Jeff Martin)
Sout >
> RX(2)
Sin >
> TX(3)
ATN >---o--||
> DTR(4)
| C1
o--||--o
C2 |
GND >
o
> GND(5)
C1 & C2 = .1uF
Software Switch Method:
Sout >
> RX(2)
Sin >
> TX(3)
ATN >
> DTR(4)
GND >
> GND(5)
Software Example for the StampII to "Send Info"
MainLoop:
DEBUG "The StampII is ALIVE!!!",cr
goto MainLoop
Software Example in QuickBasic to "switch" the DTR line:
CLS
OPEN "com1:9600,n,8,1,CD,CS" FOR RANDOM AS #1
COMaddress = &H3F8 'COM1 address location
DTR = 0 '0=OFF ; 1=ON
Value = (INP(COMaddress + 4) AND 254) + DTR
OUT COMaddress + 4, Value
WHILE 1
Data$ = INPUT$(LOC(1), #1)
PRINT Data$;
WEND
Corey-
Steve
Sout >
> RX(2)
Sin >
> TX(3)
> DTR(4)
o--/\/\--o
4.7K |
GND >
o
> GND(5)
Sout >
> RX(2)
Sin >
> TX(3)
ATN >---o--||
> DTR(4)
| C1
o--||--o
C2 |
GND >
o
> GND(5)
C1 & C2 = .1uF
Sout >
> RX(2)
Sin >
> TX(3)
ATN >
> DTR(4)
GND >
> GND(5)
MainLoop:
goto MainLoop
CLS
WHILE 1
PRINT Data$;
WEND
Corey C.
capacitor in the line which allows the reset pulse to work, but makes
hyperterminal and others happy. Our CAR-I board
(http://www.al-williams.com/awce/car1.htm) does this.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
> From: the_coin_guy@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZLcjx3usvrw_i-0K-k3H0o7UCIkR58uSgWpqDUwe16FoTKja9aG8RLg0JhrggBIY9i53bNGoZp76jeegK9jEGw]the_coin_guy@y...[/url
> Sent: Monday, March 26, 2001 5:44 AM
> Subject: [noparse][[/noparse]basicstamps] Cut ATN Line
> Hi,
> Thanks,
> Corey C.
