Please help.....servo only going one direction no matter what!
I have 6 servo motor. They are not modify for 360 degree rotation. I
was able only to rotate in CW (clock wise) but not CCW (counter clock
wise). I have read the message post by other, but it didn't help
much. I already know how a servo operate and how to program them,
but the programming doesn't work. For examples, my HS-300 hitech
servo will be position at 0 degree at 1.5ms, -90 degree at 1 ms and
+90 at 2 ms.
if for example I want to rotate the motor CCW to -90 degree with my
BS2 I would type
for x = 1 to 300
pulsout 0, 500 'where 750 is the neutral position
pause 20
next
The sevo did not go CCW but CW. If I try any ohter pulse number like
750, 900, 100, etc. I will go only in one direction CW. Why is this?
I connect my motor to an external large 6V batteries.
Please help me out. 5 ohter people are having this problem. Thanks.
Douglas
+90 at 2 ms.
BS2 I would type
for x = 1 to 300
pause 20
next
Douglas
to make a couple of assumptions. I'm assuming that it is a standard
DC motor.
I would suggest that you verify that the motor is capable of going CW
and CCW. To do this simply connect the power up in reverse, unless
there is something in the specs that say not to. A normal DC motor
will run in reverse when the current flows the opposite direction.
Changing the pulse witdth won't affect the direction of current flow
and therefore won't make the motor go the other way. Basically
connect the motor directly to the battery, see if it goes one
direction, then reverse the leads and verify that it goese the
opposite direction.
Normally when you are attempting to control the direction of a motor,
you can either do it with a dpdt relay, or use several transistors,
but you have to make the current go one way for CW and the opposite
direction for CCW.
Again, you need to pay attention to the specifications, because if
the servo has internal circuitry, you may not want to reverse
polarity on the motor. If this is the case then there should be
something in the specs that indicate how to wire the motor for
reverse direction.
I hope this helps.
Randy
randle_lee@y...
I
clock
> +90 at 2 ms.
> BS2 I would type
> for x = 1 to 300
> pause 20
> next
like
this?
Thanks.
> Douglas
the "pulsout" command. If you do:
low 0
pulsout 0,500
you get a high pulse. If you do:
high 0
pulsout 0,500
you get a low pulse. Try it!
Johan Hoffsten, Vallentuna
From: voltage91@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ffFKlX41G4ZF0MDGXaXFVGE2NlDxoDvOi6_sluQcyASlrL-kpmLbiGrCCyMWy-VSYQjzeZUNztgyn_gPMRI]voltage91@h...[/url
Sent: den 25 mars 2001 07:36
Subject: [noparse][[/noparse]basicstamps] Please help.....servo only going one direction no
matter what!
+90 at 2 ms.
BS2 I would type
for x = 1 to 300
pause 20
next
Douglas
