make a stamp kill power to itself?
Does anyone know how I can make a stamp kill power to itself. I'm
not quite sure what the outcome of this is going to be.
When started my program does a series of things, watches buttons in a
loop, and when a certain pin goes low, I want the stamp to stop
working. I don't want it in "end" mode, I want to disconnect it from
power completely.
Here's my pseudocode:
main:
do stuff
loop:
if button 1 goto shutdown
if button 2 something else
goto loop
shutdown:
<--- what to do here???
should i trigger a relay that would open the contacts and thus kill
power to the stamp here?
My application is such that when the car accessory line goes high,
the stamp turns on and does stuff; when the car accessory line goes
low, I want the stamp to turn off and draw NO power from the battery.
Next time the car is started, do the same, repeat, lather, rinse,
etc...
Is my program logic bad or can i put a relay/capacitor on the stamps
power line and when it shuts down, trigger the relay (which opens the
contacts) and thus takes power away from the stamp? Would this work
r would it produce strange results?!?
Any help on this would be greatly appreciated...!
-Chris
power completely.
main:
do stuff
loop:
goto loop
shutdown:
etc...
-Chris
accessory line) switch the stamp on and off.
-Rob
Sent: Saturday, March 24, 2001 8:50 PM
Subject: [noparse][[/noparse]basicstamps] make a stamp kill power to itself?
> power completely.
> main:
> do stuff
> loop:
> goto loop
> shutdown:
> etc...
> -Chris
break the power connection when a specific port goes high.
> How about holding a transistor to the supply on via holding a voltage on
an
> IO pin. When you change the value of the IO pin to low the transistor
shuts
> off killing the power to the stamp (hence the IO line remains low). The
> problem with this aproach would be turning it on again as the stamp would
> have to be running to initialize that line high. just a thought and
> probably not an all that good one. I like the relay idea better myself
but
> I took all this time to write this so ill send it anyway lol.
nominal sleep current of 25 microamps, it would be basically invisable to
the car battery....
fwiw
Steve
At 09:33 PM 03/24/2001 -0600, you wrote:
>If the ports normally start up in a low state, you could set up a relay to
>an
>shuts
>but
IO pin. When you change the value of the IO pin to low the transistor shuts
probably not an all that good one. I like the relay idea better myself but
> power completely.
> main:
> do stuff
> loop:
> goto loop
> shutdown:
> etc...
> -Chris
