Light Chaser...
Hey, thats a great project, i suggest if you are adding an audio input or a
mic, to filter high frequencies and to roll off the hight end of the
spectrum, so you can get the bass drum to drive the light, and maybe you can
add another mic line, or clone the audio input for an unfilter input, so if
the low end is not present then you might do some sfx with the high end, so
when you got a good bass drum kicking, you will make the lights react
different, from a solo vocal or a music bk.....
Hope it helps
bye
PS: if you need more info on how to filter out low end, let me know........
I have some sketch.....
Hope it helps
bye
