Assembly
I have always had trouble mounting hardware in project boxes.
Particularly DB connectors (9,15,25)
Can anybody suggest a simple method of making the cutout in the
project box so that it can fit nicely?
Al Najjar
Al Najjar
can be made to look good if done carefully.
Chris
> From: brownstamp@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xstK4UeKDh6RyxqwLBhy04B1u1KJNZC-5LQDnWrk8FYsmUHkM3iClJOPFvUdhxMMSmtgtpgwncSVkpA-vGc]brownstamp@y...[/url
> Sent: Friday, March 23, 2001 5:15 PM
> Subject: [noparse][[/noparse]basicstamps] Assembly
> Al Najjar
A decent DB type punch has always cost me at least $150. I've tried a few
cheaper solutions, but they don't hold up to much use and certainly can't
deal with any but the softest chassis.
If this route is too pricey, You might decide to make a drill template. I
use a #44 drill and drill through a template to get the "shape" and the
mounting holes of the hole I need. You can make this template out of 1/8"
steel plate. Start by laying the connector face down on the plate. Drill
through the mounting holes. At this point you can use long #4 screws to
mount the connector onto the plate in a backwards fashion. Scribe around
the shell of the connector to mark where your template holes will land.
Remove the connector, mark 1/16" inside your line at 3/16" spacing with a
prick punch or center punch. Try to land or "fudge" a hole to each of the
four corners. This will make your finished shape start with the right
corner dimensions. Now drill these marks with an 1/8" drill bit.
You now have a template that you can attach to the chassis after drilling
only one of the mounting holes. Drill the second mounting hole, install
screws and nuts and drill through the template and your chassis at all
remaining hole sites. This is a starting place for a small file or multiple
files to shape the hole.
I know that doesn't sound like the "simple method" you asked for, but short
of buying the right tools or using a milling machine, I have never been
able to make decent looking shaped holes in chassis any other way.
Good luck,
>Al Najjar
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________
Mike Walsh
walsh@i...
know, I know! *grin*) has what they call "Project Enclosures" which have
a "...plastic lid partial cutout for DB-9 connector"
I bought 2 of these today for a project which I need to mount a DB9 to,
but haven't actually USED it yet [noparse]:)[/noparse]
-Rich
> Al Najjar
plates already punched (from SesCom, I think). They are made to be end
plates for a series of boxes they make (Lab Box-It) and are just a bit
bigger than the D connector. The cases come with blank panels, but you can
get them extra with different holes. They already have small holes in the
four corners. We cut a square hole in the panel a bit smaller than the panel
and use self tapping screws to attach the plate. Works well enough.
A DB-9 panel is like 50 cents, a DB-25 is .75. You can also get round holes,
double d holes, XLR, SO239, etc.
None more than about a buck. You can also buy the cases, but we usually use
them with bigger boxes.
http://www.sescom.com/enclosure/
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
> From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rkBmg29f-3zYeB8pRSg7oWzZCZFwZI-rR2VZNuL70Oa7JQ-IRMO3-LEr0iD6cZiXXjiiaqqcRNHOlGJme7BaEWJYk-6m2NKe]chris@a...[/urlOn Behalf Of
> Chris Loiacono (E-mail)
> Sent: Friday, March 23, 2001 4:27 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Assembly
> If you don't want to buy the punch, use a Dremel tool. It's not
> fast, but it
> Chris
> > From: brownstamp@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pwwcQ_3sAIoIMazA9hixevYWSa9t_DTyZNX8G7EBdgBxio0uNzMxBmtL9w6Pf4Wvc9rqQGCSFx74hiU]brownstamp@y...[/url
> > Al Najjar
want and print the image out on overhead projector film. Stick the film to
the box as a template and cut away with a nibbling tool or Dremel tool. Use
a small round file to shape the curves.
used for the serial / parallel cards. I always mounted the connectors in the
case and saved the plates for later. Use the plate as a template.
> The punches are fairly expensive. One thing I've done in the past is to
buy
panel
holes,
use
you are truley a wealth of information. I enjoy your book and use it
as my main reference.
thanks!
to buy
end
bit
you can
in the
the panel
round holes,
usually use
> Al Williams
> AWC
microcontroller:
> > From: Chris Loiacono [noparse][[/noparse]mailto:chris@a...]On Behalf Of
> > To: basicstamps@y...
> > fast, but it
> > Chris
> > > From: brownstamp@y... [noparse][[/noparse]mailto:brownstamp@y...]
> > > Al Najjar
I am trying to make an Outside-template for a Dremel tool. By this I
mean using a standard routing technique used in woodworking (I do lots
of that). I have a special base for the Dremel that has a flat
circular colar. I make my template to be the dimention of the cutout
plus the radius of the colar. After many trials and errors I will
arrive at tempalte that can be lined up with the project box and
clamped to it. Then the Dremel can ride inside this template and I
can freely move the cuting bit around to remove unwanted material.
I know it works for woodworking, but the problem with project boxes is
that you don't have much space.
I will try it and update you.
Many thanks!
Al Najjar
--- In basicstamps@y..., MIKE WALSH <walsh@c...> wrote:
> Al,
a few
can't
template. I
the
1/8"
Drill
to
around
land.
with a
of the
right
drilling
install
all
multiple
but short
been
> Good luck,
> Mike
> >Al Najjar
> Mike Walsh
> walsh@i...
What kind of dremel bit to use!
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> If you are really cheap, you could hoard a bunch of old PC blockoff
plates
connectors in the
is to
> buy
end
bit
you can
in the
the
> panel
enough.
round
> holes,
usually
> use
fine, but labor intensive. For small production runs, I bought the Greelee
D punch -- the one-piece model that also does the side mounting screws. I
cranked out about 20 boxes, each with 3 D9 cutoffs, and by then the novelty
had definitely worn off. So I now let the enclosure box company do all the
punching for "a few dollars more" per panel. More time for designing,
Stamping and PICing, and less time spent punching.
Dennis
From: brownstamp@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eDBsUdp2oC4s-Z-gQrgKuB8_Y4NLq_w5C7HxeRDr7nNOcbAtf12seJv4vWzgorWIYjHnat5AobzNoYBpyg]brownstamp@y...[/url
Sent: Saturday, March 24, 2001 1:08 PM
Subject: [noparse][[/noparse]basicstamps] Re: Assembly
Wow! this is cheap but clever.
plates
connectors in the
is to
> buy
end
bit
you can
in the
the
> panel
enough.
round
> holes,
usually
> use
By this i want to know if exist one compilator/editor in assembly to BSI/BSII ?
Much Obliged
Wagner
Brasil
