BS2sx & PULSOUT
Remember that the pulsout on a BS2SX will have different setting than
it does on the stampII.
If you are like me, you have already stripped several servos trying
to make it work. If you still haven't figured it out yet, email me
again and I will give you the parameters that work for me.
Doug
> From: Rodent <daweasel@s...>
> Date: Wed, 21 Mar 2001 20:23:50 -0600
> Reply-to: basicstamps@yahoogroups.com
> Subject: [noparse][[/noparse]basicstamps] BS2sx & PULSOUT
> Anyone had any problems getting PULSOUT to work on the BS2sx? We were
> working on a servo and could not get PULSOUT to put out a steady pulse
> stream.
> Per examples found in several books, we set up a loop with a PULSOUT
> statement and a pause and we only got about 10-12 pulses out of any of the
> ports we tried.
> We wrote a FOR NEXT loop and toggled the port high and low at a high rate
> with no problems, but the PULSOUT command does not appear to work properly.
> Any ideas?
Doug
> stream.
> ports we tried.
> Any ideas?
stream.
ports we tried.
Any ideas?
individually to get some of my programs to work as i expected.
ie: dirs=%00011111... didn't seem to get all of the pins but
dir0=0
dir1=0
etc...
made everything work fine.
-pete
> stream.
> ports we tried.
> Any ideas?
