I know enough to be dangerous...
This is a good subject line that someone used once before.
I have what I hope is a simple problem. Perhaps because I can't remember
much from the EE classes I took in the 70's. (I wound up as an IE - and
probably for a good reason!)
I'm attempting to use a small current transformer on the line of an AC load,
and I want a voltage output to be proportionally linear so I can read it
with an ADC, in turn, into my controller. The dropping resistor idea is
great and simple, but whatever R value I try works up to a point, then, the
curve reverses and decreases as my load current continues to increase. What
am I missing?
Chris
am I missing?
Chris
If I understand your question, you are using a current transformer on your
AC line, and are experimenting with different value terminating sense
resistors. First, you must use a transformer rated to the max current being
measured. If it's too small, the core will saturate, and output will fall
off. Second, current transformers usually come with a recommended
terminating resistor. (Some units have it built-in). Using a larger value
than recommended can cause saturation at the high end. It is OK to use a
smaller resistor, but volts-out/amp will be proportionately less.
Ray McArthur
To: Basicstamps Egroup (E-mail) <basicstamps@yahoogroups.com>
Sent: Wednesday, March 21, 2001 1:40 PM
Subject: [noparse][[/noparse]basicstamps] I know enough to be dangerous...
load,
the
What
> am I missing?
Yup, that's basically the question. I have the CT secondary into a FW
Bridge. The DC points on the bridge have the sense resistor and a filtering
cap across them. The - side goes to ground and the + is for my analog input.
The problem is that any value resistor that I try, down to 50 ohms has the
output reducing (seems like the high end saturation you mention) instead of
increasing once a certain level has been reached. My CT is a 1,000 turn
unit, and I'm only sensing a load that goes from zero up to about 1.6 Amps.
I am hoping to use this for larger loads, and I'm not getting any closer.
Perhaps I only need something like 5 or 10 ohms.....Hmmmm. Since the CT is a
constant current source, is there any danger in using such a small
resistance?
______________________ +
CT 100uF = \ R?
______________\_______ gnd
Chris
> From: Ray McArthur [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6KSvGDoLl3HQQXqiHtgTiHsK7xfp5XO-69-wCyOFCVXVPACRLG_xLMEXQXFVh2Rt9T11DTossByD3eYLnQ]rjmca@u...[/url
> Sent: Wednesday, March 21, 2001 3:56 PM
> Subject: Re: [noparse][[/noparse]basicstamps] I know enough to be dangerous...
> Chris:
> transformer on your
> max current being
> output will fall
> a larger value
> OK to use a
> Ray McArthur
> From: Chris Loiacono (E-mail) <chris01@t...>
> line of an AC
> load,
> I can read it
> resistor idea is
> point, then,
> the
> to increase.
> What
> > am I missing?
Yes, the CT is a constant source and could even be shorted without damage.
If the smaller resistors don't solve the problem, the core is too small.
You need a conservatively rated unit because the FWB introduces an
additional 1.4 volts on the secondary. Digikey lists 50/60 Hz units on page
630 of their catalog. They start at 5 amps on up, and start at $7.80.
Ray Mc
filtering
input.
of
Amps.
a
> resistance?
You may need to rectify it or use an RMS convertor like the AD-637.
On Wed, 21 Mar 2001 13:40:01 -0500 "Chris Loiacono (E-mail)"
<chris01@t...> writes:
> remember much from the EE classes I took in the 70's. (I wound up as an
IE -
> and probably for a good reason!)
> AC load, and I want a voltage output to be proportionally linear so I
can
> read it with an ADC, in turn, into my controller. The dropping resistor
idea
> is great and simple, but whatever R value I try works up to a point,
> then, the curve reverses and decreases as my load current continues to
> increase. What am I missing?
> Chris
I just needed a different winding. Thanks to Ray McArthur, I found my CT to
be undersized, although it didn't exacly act as expected, a larger one
solved the problem. Now, I have a simple (4 component) circuit for reading
proportional values from AC lines. Thanks, Ray, and all who responded!
Chris
> From: agarb@j... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ThZJHiG11TCO08AM6vJHwg0Fl4zoM2lKYO-568vOzXML0Uw32rGgqyo875mXr-XwSI12lNKJcGk]agarb@j...[/url
> Sent: Thursday, March 22, 2001 6:27 PM
> Does this current transformer convert the AC into a DC
> representation?
> wound up as an
> IE -
> linear so I
> can
> dropping resistor
> idea
> a point,
> continues to
> > Chris
