Motormind Stuff
Here are some code snippets -- Like you, I'm trying to get the motor control
going.
'*** ports for output to MM modules
OUTPUT 15
OUTPUT 14
'*** ports for input from MM modules
INPUT 13
INPUT 12
'*** set up a variable for which motor to control -- 0 = right, 1 = left
Which_Motor VAR BYTE
'*** motor distance count in hex
Count_Hex VAR WORD
Count_High_Hex VAR Count_Hex.HIGHBYTE
Count_Low_Hex VAR Count_Hex.LOWBYTE
'*** set up duty cycle variable in hex
Duty_Cycle_Hex VAR BYTE
'*** right motor command send & receive ports
RM_Send CON 15
RM_Rec CON 13
'*** left & motor command send & receive ports
LM_Send CON 14
LM_Rec CON 12
'*** set the right & left command send ports to high
HIGH RM_Send
HIGH LM_Send
'*** use the right motor
Which_Motor = 0
'*** set motor count
Count_Hex = 32
GOSUB Motor_Count
PAUSE 5000
'*** set motor duty cycle
Duty_Cycle_Hex = $7F
GOSUB Motor_DC
'*** run selected motor for a fixed count ********************
Motor_Count:
IF Which_Motor = 0 THEN Count_Right
Count_Left:
DEBUG "sending command to run left motor ",DEC Count_High_Hex, DEC
Count_Low_Hex," counts",CR
SEROUT
LM_Send,1021,[noparse][[/noparse]$55,$86,Count_High_Hex,Count_Low_Hex,Duty_Cycle_Hex]
GOTO Count_End
Count_Right:
DEBUG "sending command to run right motor ",DEC Count_High_Hex, DEC
SEROUT
RM_Send,1021,[noparse][[/noparse]$55,$86,Count_High_Hex,Count_Low_Hex,Duty_Cycle_Hex]
Count_End:
RETURN
'*** run motor at fixed duty cycle **********************************
Motor_DC:
IF Which_Motor = 0 THEN Motor_DC_Right
Motor_DC_Left:
DEBUG "sending command to run left motor at ", DEC Duty_Cycle_Hex,"%
duty cycle",CR
SEROUT LM_Send,1021,[noparse][[/noparse]$55,$83,Duty_Cycle_Hex]
GOTO Stop_Motor_DC
Motor_DC_Right:
DEBUG "Right motor running at ",DEC Duty_Cycle_Hex,"% duty cycle",CR
SEROUT RM_Send,1021,[noparse][[/noparse]$55,$83,Duty_Cycle_Hex]
Stop_Motor_DC:
RETURN
going.
OUTPUT 15
OUTPUT 14
INPUT 13
INPUT 12
Count_Hex VAR WORD
RM_Send CON 15
RM_Rec CON 13
LM_Send CON 14
LM_Rec CON 12
HIGH RM_Send
HIGH LM_Send
Which_Motor = 0
Count_Hex = 32
GOSUB Motor_Count
PAUSE 5000
GOSUB Motor_DC
Motor_Count:
Count_Left:
SEROUT
GOTO Count_End
Count_Right:
SEROUT
Count_End:
RETURN
Motor_DC:
Motor_DC_Left:
duty cycle",CR
GOTO Stop_Motor_DC
Motor_DC_Right:
Stop_Motor_DC:
RETURN
you using some other interface?
Jeff
it is actually 2 bytes in length. I was working on bump switches and I
wanted the bot to turn about 45 degrees. 32 counts is about right in this
case.
I didn't include all the code because it would be a bit confusing.
Basically, what I was doing was moving the 'bot forward at a fixed duty
cycle until it hit a limit switch, then I was stopping, rolling the wheel on
the opposite side back about 1/2 turn, then going forward again.
The MotorMind is kind of limited in some respects, so you have to work
around some of its quirks to do what you want.
> Thanks for the code Rodent. Is "Count_hex" fixed at 32 all of time or are
