Decode Infrared codes
I'm using a radioshack infrared detector module (model GP1U52X). I
have the output of the module hooked up to an input pin of a bs2.
I'm wondering what the best way is to see the code from a remote
control that I point towards the module.(What basic stamp command
would I use to count the pulses). All I really want to do is debug
the code to my pc screen in the form of 1's and 0's.
Charlie
Charlie
Charlie
Stamp's interinstruction time is just fast enough to catch the remote. Since
most remotes use a pulse width, you can read the data with PULSIN. However,
you have no processing time until the packet is done. So:
pulsin 0,firstbit
pulsin 0,secondbit
' now do stuff
You can't write:
first:
pulsin 0, firstbit
if firstbit<1000 goto first
' too late!
The problem is, how do you know when the remote sends a start bit. My code
did NOT know. It simply read an entire packet, checked it, and if it was
wrong it would read it again. That works over time because there is a large
gap between packets. Eventually you will sink up. The remotes know they may
not be reliable, so most of them send "repeats" as long as you hold the key.
This leads to other problems you can work around. My remote drove a little
robot (the BoeBot). If you program it to move forward, for example, while
pressing the 2 key. That was OK. But if you said, press 2 to go forward and
then it will continue going forward until you press, say, 5 that worked
poorly. Why? Because the IR read routine had to "time out" reading the 8 or
9 bits before you could do anything. So sending it a steady stream of IR was
fine, but not sending it IR gave you a few 100 milliseconds where nothing
else could happen.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller:
http://www.al-williams.com/awce/pak1.htm
> From: charlieb83@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lbCOPW331sNVn0EbH5306d-B3Bl_pYb1LrCir7-Wt9nkV0LLh5QmyYsXmEUzm0HuGWaF7bWkMZCcxuwe9g]charlieb83@h...[/url
> Sent: Monday, March 19, 2001 12:44 AM
> Subject: [noparse][[/noparse]basicstamps] Decode Infrared codes
> Thanks,
> Charlie
You've got Elektor too ? I've seen this article (in Belgium) about different
coding systems by constructors, it looks pretty interesting !
You may find information at this address as well :
http://www.ustr.net/infrared/infrared1.shtml
Best regards,
Phil.
Sent: Monday, March 19, 2001 3:28 PM
Subject: RE: [noparse][[/noparse]basicstamps] Decode Infrared codes
> I did an article for this in Elektor a while back. The problem is the
Since
However,
> pulsin 0,firstbit
> pulsin 0,secondbit
> ' now do stuff
> You can't write:
> first:
> pulsin 0, firstbit
> ' too late!
large
may
key.
and
was
> else could happen.
> Regards,
> Al Williams
> AWC
> > From: charlieb83@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ErlTmY7aIum-7bgWdJpVL2_M0Tu4hv38tzwWO_458nBjPaktMxbKLBKI7JyFilqmRqC37j9ArY6Lfw]charlieb83@h...[/url
> > Thanks,
> > Charlie
Is the SX stamp marginal on speed for this application?
thanks
Sent: Monday, March 19, 2001 12:06
Subject: Re: [noparse][[/noparse]basicstamps] Decode Infrared codes
> Hi Al !
different
> Best regards,
> Phil.
> From: "Al Williams" <alw@a...>
> Since
> However,
> > pulsin 0,firstbit
> > pulsin 0,secondbit
> > ' now do stuff
> > You can't write:
> > first:
> > pulsin 0, firstbit
> > ' too late!
code
> large
> may
> key.
little
while
> and
> or
> was
nothing
> > else could happen.
> > Regards,
> > Al Williams
> > AWC
> > > From: charlieb83@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=o6s81RMm0l5KWZvKbDTjntZxZ4YEp-Ep-GG-2xNsXh-UnFcoOmYhXuXmeEGAktZdC72JCl44pLdYsw]charlieb83@h...[/url
> > > Thanks,
> > > Charlie
pulsin 0,firstbit
pulsin 0,secondbit
How many bits do I want to read? Also, how can I check (as you said)
this stream of bits to see if its the right one?
Again, you're help is greatly appreciated.
Thank you,
Charlie
Well, that depends on the remote in question. Different ones use different
formats, word lengths, etc. My code used a Sony remote. You can read just
some of the bits if you only want to decode some keys (the code at
stampsinclass.com does this).
The trick is to look at the length of the firstbit and compare it to how
long the AGC or start pulse is supposed to be (with some error margin, of
course).
Have a look at the code at www.stampsinclass.com -- The Elektor code was
written for Parallax, so I don't know if they can release it or if Elektor
owns the rights outright. Andy can you shed some light on this? From my
point of view, Parallax owns that code, but I don't know what rights they
may have given away for it?
Al Williams
AWC
* Control 8 servos: http://www.al-williams.com/awce/pak8.htm
> From: charlieb83@h... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rmnVpCirvuB7DgPoyMi755e7SaPK31cgDfa0NEuwnDRJaoGlxjUkdi_KqKLqdjcdA70DniA4cazSSSv8syw]charlieb83@h...[/url
> Sent: Monday, March 19, 2001 10:11 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Decode Infrared codes
> Thanks for you're help Al. When you say:
> pulsin 0,firstbit
> pulsin 0,secondbit
> Thank you,
> Charlie
or one of the newer stamps maybe they can test it, the values for the
leader 310, 320 and the values for the var (A) will need to be changed, The
value of pulsin changes per the speed of processor. I have made changes to
this program but Im not sure if the stamp supports some of the changes, In
the value1 subprogram I have a loop to place all bit values into a word
rather than use 12 lines but this may be easier to start with.
good luck
If someone gets it working let me know
larry gaminde
' IR CODE READER SONY TYPE
' LARRY GAMINDE LGAMINDE@T...
' PIC16F84-10 USED IN THIS EXAMPLE AND TIMING IS DEPENDENT
' ON PROCESSOR SPEED 10MHZ
' I USED A SERIAL BACKPACK ON PORTB.3 FOR DISPLAY AND DEBUGGING
' INPUT FROM RADIO SHACK 40KHZ RECEIVER TO PORTB.1
DEFINE OSC 10
TRISB= %01000000
A VAR BYTE(16)
I VAR BYTE
LEADER VAR WORD
VALUE VAR WORD
PAUSE 500
SEROUT2 PORTB.3, $4054,[noparse][[/noparse]254,1]
PAUSE 100
SEROUT2 PORTB.3, $4054,[noparse][[/noparse]" IR CODE READER"]
PAUSE 2000
MAIN: LEADER = 0 'LOOK FOR LEADER OR START BIT
PULSIN PORTB.1, 0, LEADER
IF (LEADER < 310) THEN MAIN
IF (LEADER > 320) THEN MAIN
FOR I = 0 TO 11 'I USED 8 OF THE 12 BITS FOR DISPLAY
PULSIN PORTB.1, 0, A(I)
NEXT
FOR I = 0 TO 11
IF A(I) > 150 THEN ONE
IF A(I) < 130 THEN ZERO
'NEXT THREE LINES USED FOR DEBUGGING
SEROUT2 PORTB.3,$4054,[noparse][[/noparse]254,1]
SEROUT2 PORTB.3,$4054,[noparse][[/noparse]"A",DEC I,DEC A(I)]
PAUSE 2000
ONE:
A(I) = 1
GOTO ENDD
ZERO:
A(I) = 0
ENDD:
NEXT
VALUE1:
VALUE.BIT0 = A(0)
VALUE.BIT1 = A(1)
VALUE.BIT2 = A(2)
VALUE.BIT3 = A(3)
VALUE.BIT4 = A(4)
VALUE.BIT5 = A(5)
VALUE.BIT6 = A(6)
VALUE.BIT7 = A(7)
VALUE.BIT8 = A(8)
VALUE.BIT9 = A(9)
VALUE.BIT10 = A(10)
VALUE.BIT11 = A(11)
VALUE.BIT12 = 0
VALUE.BIT13 = 0
VALUE.BIT14 = 0
VALUE.BIT15 = 0
SEROUT2 PORTB.3,$4054,[noparse][[/noparse]" ",DEC VALUE]
SEROUT2 PORTB.3,$4054,[noparse][[/noparse]254,192]
SEROUT2 PORTB.3,$4054,[noparse][[/noparse]BIN VALUE]
PAUSE 2000
IF VALUE = 4074 THEN VALUE = 1
IF VALUE = 4042 THEN VALUE = 2
IF VALUE = 4010 THEN VALUE = 3
IF VALUE = 3978 THEN VALUE = 4
IF VALUE = 3946 THEN VALUE = 5
IF VALUE = 3914 THEN VALUE = 6
IF VALUE = 3882 THEN VALUE = 7
IF VALUE = 3850 THEN VALUE = 8
IF VALUE = 3818 THEN VALUE = 9
IF VALUE = 3786 THEN VALUE = 0
SEROUT2 PORTB.3,$4054,[noparse][[/noparse]" BUTTON # ",DEC VALUE]
LEADER = 0
VALUE = 0
PAUSE 500
GOTO MAIN
> pulsin 0,firstbit
> pulsin 0,secondbit
> Thank you,
> Charlie
pulsin statements the portb.? need to be the pin numbers your using for
input and output
DEFINE OSC 10
TRISB= %01000000
TOTAL VAR BYTE
LEADER VAR WORD
VALUE VAR WORD
A VAR BYTE(16)
PAUSE 500
PAUSE 100
PAUSE 2000
MAIN:
PULSIN PORTB.1, 0, A(0)
PULSIN PORTB.1, 0, A(1)
PULSIN PORTB.1, 0, A(2)
PULSIN PORTB.1, 0, A(3)
PULSIN PORTB.1, 0, A(4)
PULSIN PORTB.1, 0, A(5)
PULSIN PORTB.1, 0, A(6)
PULSIN PORTB.1, 0, A(7)
PULSIN PORTB.1, 0, A(8)
PULSIN PORTB.1, 0, A(9)
PULSIN PORTB.1, 0, A(10)
PULSIN PORTB.1, 0, A(11)
'PULSIN PORTB.1, 0, A(12)
'PULSIN PORTB.1, 0, A(13)
'PULSIN PORTB.1, 0, A(14)
'PULSIN PORTB.1, 0, A(15)
FOR TOTAL = 0 TO 11
IF A(TOTAL) > 150 THEN ONE
IF A(TOTAL) < 130 THEN ZERO
SEROUT2 PORTB.3,$4054,[noparse][[/noparse]"A",DEC TOTAL,DEC A(TOTAL)]
PAUSE 2000
ONE:
A(TOTAL) = 1
GOTO ENDD
ZERO:
A(TOTAL) = 0
ENDD:
NEXT
VALUE1:
VALUE.BIT0 = A(0)
VALUE.BIT1 = A(1)
VALUE.BIT2 = A(2)
VALUE.BIT3 = A(3)
VALUE.BIT4 = A(4)
VALUE.BIT5 = A(5)
VALUE.BIT6 = A(6)
VALUE.BIT7 = A(7)
VALUE.BIT8 = A(8)
VALUE.BIT9 = A(9)
VALUE.BIT10 = A(10)
VALUE.BIT11 = A(11)
VALUE.BIT12 = 0 'A(12)
VALUE.BIT13 = 0 'A(13)
VALUE.BIT14 = 0 'A(14)
VALUE.BIT15 = 0 'A(15)
DISPLAY:
PAUSE 2000
LEADER = 0
VALUE = 0
PAUSE 500
DONE: GOTO MAIN
"L .Gaminde" wrote:
> Here is some testing I did using PBP and a 16f84-10. If someone has an sx
> good luck
> larry gaminde
> DEFINE OSC 10
> TRISB= %01000000
> A VAR BYTE(16)
> I VAR BYTE
> LEADER VAR WORD
> VALUE VAR WORD
> PAUSE 500
> PAUSE 100
> PAUSE 2000
> NEXT
> FOR I = 0 TO 11
> PAUSE 2000
> ONE:
> A(I) = 1
> GOTO ENDD
> ZERO:
> A(I) = 0
> ENDD:
> NEXT
> VALUE1:
> VALUE.BIT0 = A(0)
> VALUE.BIT1 = A(1)
> VALUE.BIT2 = A(2)
> VALUE.BIT3 = A(3)
> VALUE.BIT4 = A(4)
> VALUE.BIT5 = A(5)
> VALUE.BIT6 = A(6)
> VALUE.BIT7 = A(7)
> VALUE.BIT8 = A(8)
> VALUE.BIT9 = A(9)
> VALUE.BIT10 = A(10)
> VALUE.BIT11 = A(11)
> VALUE.BIT12 = 0
> VALUE.BIT13 = 0
> VALUE.BIT14 = 0
> VALUE.BIT15 = 0
> PAUSE 2000
> LEADER = 0
> VALUE = 0
> PAUSE 500
> GOTO MAIN
> > pulsin 0,firstbit
> > pulsin 0,secondbit
> > Thank you,
> > Charlie
