a basic question
i am a newbie at this and just used the basic stamp
for the first time . its the basic stamp 2sx and i
connected it as per the instructions given in the
manual . that is with a 9 v battery and the serial I/O
pins .
however on downloading a simple program to run Hello
world , it gives me an error saying "tokenize
successful , download failed "
the power led glows so it seems i dont have a problem
with the power connections .
help !!
thanks
avi
__________________________________________________
Do You Yahoo!?
Get email at your own domain with Yahoo! Mail.
http://personal.mail.yahoo.com/
pins .
help !!
thanks
avi
Do You Yahoo!?
ON THIER HOME PAGE. <end if rant> (rant directed at Parralax not
you Avi)
Welcome to the club. Since the problem is rarely the Stamp, you
might check your cable, make sure the pins are exactly as per the
diagrams.
Then search this list for the problem and you'll find a few great
suggestions.
Dave
> pins .
> help !!
> thanks
> avi
> Do You Yahoo!?
> http://personal.mail.yahoo.com/Avi)
STAMPW.EXE (v1.091+) for Windows 9x and STAMP2SX.EXE for DOS.
Header should be '{$STAMP BS2sx}
Other than that, it could be the cable.
> This is a very frequent question, and one I WISH PARALLAX WOULD PUT
> ON THIER HOME PAGE
> diagrams.
> suggestions.
> > pins .
if going through one of the i/o pins it wont read
> I/O
> pins .
> problem
> help !!
> thanks
> avi
> Do You Yahoo!?
Do You Yahoo!?
stamp. I use the BS-II and in v1.096 of the editor, the command is in the
'run' menu, choose 'identify'. A shortcut is ctrl-I.
I have had a similar problem with a program I d/l off the web (demonstrated
how to interface to MAX186 A/D). It would tokenize, but not d/l. Other
programs I had worked just fine. Never looked into why this was happening -
I just rewrote the program and it worked.
--Craig
From: avi bhagtani [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YzHI802vgfPGHaBgjwQNYf64WpKo4vIkvawsvSbjNLUsmFQPstLs6v4bQXMSOv3iTx8a9qxNxV0]ronals22@y...[/url
Sent: Friday, March 16, 2001 6:01 PM
Subject: [noparse][[/noparse]basicstamps] a basic question
pins .
help !!
thanks
avi
Do You Yahoo!?
there is a ground common to the serial input from the
computer, and power(9v) and the serial lcd connected
to an i/o pin and ground and 9v.
> I/O
> pins .
> problem
> help !!
> thanks
> avi
> Do You Yahoo!?
Do You Yahoo!?
Check to make sure your battery is at a full charge. I've found that
as the battery starts losing power, the light stays on, but you can't
download.
-Chilton
